diagonal bed
diagonal bed
Postby saywhatthat » Tue Mar 09, 2021 11:31 pm
I been asked to build a one person trailer. The short the better .What do you think of a diagonal bed. Made from fiberglass /foam panels .the blue cabinets brown floor pink bed .will be pulling with old honda 750 motorbike . So need to be light. will have lifting roof .Head to door
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: diagonal bed
Postby Gold5one » Thu Mar 11, 2021 8:52 am
Why Not? - Looks like a neat idea-- and I want orange shag carpeting, too. :thumbsup:
Mark
viewtopic.php?f=50&t=74522
Weekender-XL build journal
sold-2018
Gold5one
Images: 157
Re: diagonal bed
Postby kmack67.km » Thu Mar 11, 2021 12:34 pm
How wide will the trailer be? I can't think of a reason not to do this, but if it isn't very wide, the diagonal will barely be any longer than the long side of it.
Kevin
Sent from my SM-G950W using Tapatalk
kmack67.km
Re: diagonal bed
Postby QueticoBill » Thu Mar 11, 2021 3:02 pm
would a standard sleeping pad fit or will mattress (and bedding?) have to be custom cut?
QB
QueticoBill
Images: 22
Re: diagonal bed
Postby Socal Tom » Thu Mar 11, 2021 4:09 pm
I usually sleep diagonally anyhow. Does the bed have to be cut that way? Why not make the bed rectangular and let him sleep sideways on it?
Socal Tom
Re: diagonal bed
Postby tony.latham » Thu Mar 11, 2021 5:22 pm
I think it's an idea... but I also think it would make for inefficient use of space where storage is tight anyway.
:thinking:
Re: diagonal bed
Postby Tomterrific » Thu Mar 11, 2021 6:06 pm
Making the camper longer and narrower will make it easier to tow, less wind drag.
I love thinking up designs so here is one. Floor 3 x 7. Side walls, one foot high or less. The top is hinged at the end, the other end has a panel that lifts into the top to make a lopsided A frame. The sides are triangles that pull up into the A. Storage is lashed to the top. Of course, the hard part is the details.
Tt
Tomterrific
Re: diagonal bed
Postby working on it » Fri Mar 12, 2021 8:02 am
Tomterrific wrote:Making the camper longer and narrower will make it easier to tow, less wind drag....
tony.latham wrote:... but I also think it would make for inefficient use of space where storage is tight anyway...
* Wind resistance would be my first concern, if towing with a motorcycle. Narrow and long, especially if just for a solo camper; the "cabinets" could be replaced by hanging mesh along the sidewalls (for clothes and consumables), and a hard storage box at the front...with or w/o access from the outside...(for necessary gear). One member (eggsalad)built a long & narrow trailer that would work for your customer
http://www.tnttt.com/viewtopic.php?f=50&t=57667
eggsalad's so-called coffin build.jpg (85.93 KiB) Viewed 2241 times
173193172890148599
working on it
Images: 457
Re: diagonal bed
Postby aggie79 » Sun Mar 14, 2021 8:48 am
Tt
I agree with Tom. Here's a good example of a narrow and long motorcycle trailer:
http://www.tnttt.com/viewtopic.php?p=1075207#p1075207
Return to Member Designs
