Is it possible that you racked it when adding the second skin? That is the type of thing I am concerned with.
I really dislike do overs but that is a place I think it happens...
Tony makes it look easy....wink
Now off to figure out how to disassemble a hatch
I think it was built into it. One of my spars is not perpendicular and from there on the others are off as well. I built it on the trailer and didn't notice everything off so I assumed it was good.western traveler wrote:Is it possible that you racked it when adding the second skin?
That he certainly does. Trying to duplicate his work over the last year has shown me what a craftsman he is. When I grow up, I hope to be half as good at this as he is. And I haven't even tried to figure out the welding yetwestern traveler wrote:Tony makes it look easy.
Trying to duplicate his work...
I do have one question. Will I need to block the new spars. I will attach them to the blocking that is already attached. Do I need to use blocking to lock the new spars or will the two pocket hole screws be enough?
I know that earlier I said I thought it was not from the skinning process but now I am not so sure. I went to align the plywood with the bottom spar and I could not get the skin square on the frame. the bottom spar like the rest of the build was not perfectly square so I may have put the twist in making it square. To hopefully put everything on without twisting it, I started at the hinge end and worked to the curve. I, because I didn't want to pull two sets of staples if I had to redo the exterior again, started with only one row of staples down the side. Don't do that! Run two sets on each side. 1/8 or 3mm plywood may bend but it doesn't want to. At about the 3rd interior spar, it wouldn't bend without the second row of staples down the side to hold it in place. Here is the hatch on the cabin.western traveler wrote:Is it possible that you racked it when adding the second skin?
I have a hatch!!
I think, looking back on it, pay careful attention to the framing and the skinning will not be a problem. Since I initially lined up on a spar that wasn't aligned just right, it threw off the skin placement. That hatch framing requires more care than the other structural activities.GarthB wrote: After seeing the lessons you learned with skinning your hatch and keeping it properly aligned, that seems like it may be the most challenging portion. I appreciate you sharing everything you figured out! Looking forward to following the remainder of your build.
Sounds like a great trip. Hope you didn't spend too much time thinking about the hatch. It was definitely an execution issue. Now I know where I need to be especially careful.tony.latham wrote:I'm just back from a nearly month-long camping trip in the southwest.
