AKcargo wrote:Thanks guys, great info so far. I should have specified that the 2x3 steel tongue and frame are already square tube, and the spring hangers are welded directly to it. . Flboy, this is exactly the kind of info I’m looking for, thanks. Adding a center member to the tongue won’t be too bad. My joists are 24” but with a 3/4 plywood floor and no weight in the center of the joist span I think I’m fine there. What size is the perimeter of your frame? Thanks
Oh yeah, I’m towing with a 2005 Toyota Tundra 4.7.
flboy wrote:..... This is what my sticker says with the three mods....
Grummy wrote:flboy wrote:..... This is what my sticker says with the three mods....
How Interesting! Earlier I thought I read one members tag said 3500lb with his 5200lb axle, and yours they rated at 3350lbs gross with that same axle capacity. And again, a lot of us know how weight creep can catch up in a hurry. It's exactly why I keep a spreadsheet of the weight of everything.
Is your suspension mounted on an angle bolted under the frame like my boat trailer example ? Or do that have hangers welded right to the frame ?
I guess this really shows just where a manufacturer will draw the line regards liabilities on our perfect size of choice 6x12 trailer. Makes me really curious then, if when they build a 6x12 tandem axle, whether the frame itself gets any change, or as I would assume, just simply the longer addition of the underframe angle to accommodate the tandem setup gives them the confidence to raise the GVRW without changing anything regards the floor joists or main frame rails.
If I were the OP, I would simply get a weld shop (if he is not able to do it himself) to make an appropriate 6 foot long angle suspension mount to put his axle on. When the new axle assembly is slid into place, he will also be able to fine tune his tounge weight with the new axle placement.
