You might mention in your write up that you don't *have* to make the ve. to USB cables, Victron sells them. It's just a lot more expensive than making them.
bdosborn wrote:You might mention in your write up that you don't *have* to make the ve. to USB cables, Victron sells them. It's just a lot more expensive than making them.
bdosborn wrote:Can you use the Raspberry Pi's Ethernet port to set up a LAN? Can you pick the WiFi LAN address? Can you have the Pi bridge to a local WiFi if one is present? I've been using my phone for WiFi in the camper but the Raspberry Pi approach is looking pretty cool.
bdosborn wrote:I'll be using this on the van electrical, I wish I'd known about it for the trailer:
Nifty Heat Shrink Labels
