HandiCramper
Re: HandiCramper
Postby twisted lines » Sat Aug 07, 2021 10:42 am
Adding pieces, cutting fitting and tossing pieces.
Outsides cut with scroll saw, inside converted to hot wire.
Hot wire conversion.jpg (71.93 KiB) Viewed 1020 times
This didn't work taking it apart, just one time :(
Darn't again.jpg (69.3 KiB) Viewed 1009 times
Racking up; And Rapin foam
twisted lines
Re: HandiCramper
Postby twisted lines » Wed Aug 18, 2021 7:14 pm
little more work in the back, little more to fix :cry:
Whole back.jpg (87.88 KiB) Viewed 965 times
Back top.jpg (65.48 KiB) Viewed 965 times
Paint less.jpg (81.07 KiB) Viewed 965 times
SHUT THE BACK DOOR ;)
twisted lines
Re: HandiCramper
Postby twisted lines » Wed Aug 18, 2021 7:17 pm
More inside fitting :thinking:
In back.jpg (55.67 KiB) Viewed 964 times
twisted lines
Re: HandiCramper
Postby twisted lines » Sun Sep 05, 2021 3:17 pm
With the spacer's behind the hinge, to make room for the soft T moulding / Q seal,
Flat almost square, and a challenge for the first / last & only; door i have made.
Back Door.jpg (70.46 KiB) Viewed 912 times
twisted lines
Re: HandiCramper
Postby S. Heisley » Sun Sep 05, 2021 6:03 pm
:applause: Nicely done! Looks like you're almost ready to roll!
Re: HandiCramper
Postby Graniterich » Sun Sep 05, 2021 9:44 pm
Are you going, to add a drip rail above?
Graniterich
Re: HandiCramper
Postby twisted lines » Mon Sep 06, 2021 9:39 am
S. Heisley wrote::applause: Nicely done! Looks like you're almost ready to roll!
You are close enough you may see it in a rare pass through the biggest 55 zone I know of; Next Year :D
twisted lines
Re: HandiCramper
Postby twisted lines » Mon Sep 06, 2021 10:26 am
Graniterich wrote:Are you going, to add a drip rail above?
I am hoping I don't need to, but the little curl I have here is a big unknown to me.
I had drawn one similar to JazzVinal's, Foamy 2 may have it :lol:
In time the 225 deg Awning I don't have may help!
While in storage It will be pampered much more then in use. ;)
Slide in.JPG (32.44 KiB) Viewed 831 times
:lol:
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Dec 24, 2021 8:09 pm
finaly got to see how close the caulk matches the paint :thumbsup:
Latched the back door
Batterys Charging 1.5A charger / 45A not in use; May need it
twisted lines
Re: HandiCramper
Postby twisted lines » Thu Jan 20, 2022 8:39 pm
Boat / NO Boat
I can't lift no stinking boat :thumbdown:
Drawing turned template
twisted lines
Re: HandiCramper
Postby S. Heisley » Fri Jan 21, 2022 7:07 pm
Looking forward to it! Are you coming to Antlers the last weekend in April?
Re: HandiCramper
Postby lfhoward » Fri Jan 21, 2022 7:35 pm
Your door fitment looks like it came out really well! Nice work.
lfhoward
Re: HandiCramper
Postby twisted lines » Sat Jan 22, 2022 1:50 pm
If you see an Old guy walking like a drunk don't throw pennies ;)
A good friend of mine use to camp and fish every year there same time;
told me about it several years ago :thumbsup:
twisted lines
Re: HandiCramper
Postby twisted lines » Sat Jan 22, 2022 1:58 pm
lfhoward wrote:Your door fitment looks like it came out really well! Nice work.
Thank you!
I didn't expect it to protrude, But I used what I asked for :lol:
Found nice 2" tube wire way's that I wasted, and didn't expect to be this far out on the edge.
You are one that could use that 45A output charger :thinking: but I wouldn't let you test it at my house :lol:
twisted lines
Re: HandiCramper
Postby twisted lines » Sat Feb 05, 2022 12:48 pm
Tackling the Hole's for the Rack / panal fitting inside, so I can punch holes through and though Headboard :NC
Almost ready to tack together :frightened: Cleaning & Thinking something's not done!
That 270* Awning!
I just Ordered a dam tent :crazy:
twisted lines
