tony.latham wrote:provided by slanted roof line in front vs a straight box?
The rear of your camper is just or more important than the front since the front is shielded by your tow vehicle to one degree or another....
Mine's not a foamy, but it is a squareback "box", so I was trying to mitigate air "drag" when building my 4x8. It was
supposed to end up under 1000 lbs, but wasn't even close, made of 3/4" plywood with lotsa steel inner bracing/hines & latch hardware/bolts etc; but I tried to fit it within the wind shadow of my wife's '08 Chevy Cobalt (it was going to be her trailer, but I took it over) or of my '09 Chevy HHR Panel, both with a towing capacity of 1000 lbs.
I wanted the front of the trailer to have a sloped roofline, to match the side profile(s) of those vehicles, but they were different, at approximately 35 degrees for the HHR an 55 for the Cobalt. I compromised at 45 degrees, which made cutting the plywood side profiles & doors much easier, and determined that the height of the leading edge of the front slope should match the height of the Cobalt's rear wing, 40" (or 42", I forget) off the ground. That fit nicely with the floor height of 24", which left 16-18" for footroom below the angled front slope (in this trailer, you sleep feet forward the nose).
Just for reference: the drag coefficient for the Cobalt is .32, and the HHR is .354, which we'll come back to, later.
- Trailer designed to follow either HHR or Cobalt, 45 degree angle slope a compromise.jpg (190.66 KiB) Viewed 3033 times
At the rear, I knew there'd be drag induced by the vertical hatch, so when I covered the gap between hatch and main body, I used excess semi-rigid conveyor-belt material, which would rise up into the airstream, and cause eddies to reduce the suction.
- rear hatch (gap) cover acts as an airfoil.JPG (84.18 KiB) Viewed 3033 times
I did have some road dust infiltrating past the rear hatch into the galley/storage area, but I added weatherstripping and right-angle clamps/latches, which eliminated the problem.
Since the trailer was way too heavy for either of the pre-build designated tow vehicles, I tow it with my '04 Chevy 2500HD pickup, whose open (or semi-open, now covered) 8ft bed made the "in the wind shadow" effect moot. I never tried to evaluate mpg figures with and without the trailer attached, because the heavy truck (with 1000+ lbs of tools & gear in the bed, and equipped with 4.10 gears and a thirsty 6.0 liter gas engine) gets about the same mpg at 75 mph, towing or not (as I found out while towing my old Chevelle drag car on a tandem axle open trailer). In fact, it hardly notices the 4x8 squareback trailer back there.
When I resume camping (after a year's interlude), I might just use my '01 BMW X5 E53 as the tow vehicle. I got it as my final project car, intending to camp and soft-road travel in it (before my health problems got a bit worse), but it can easily pull the 2225 lb trailer (whether or not I install a brake controller in it...it will cost a bunch to adapt off-the-shelf, non BMW stuff to it), at least to local state parks around N.Texas or S.Oklahoma.
The X5 has a good drag coefficient of .36, so it might provide the "wind shadow" effect I initially was hoping for, with the smaller vehicles I was designing the trailer for.
