Help with AutoDesk Inventor??
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby Steve Frederick » Sun Feb 18, 2007 3:53 pm
My son is taking design courses at college. He has a student version, (a license from the school) of Auto Desk Inventor. We got it activated..I think!!
When an attempt to open a file is made, the program closes! I'm thinking that there may be a helper program, or file service that has to run in the background?? Anyone here familiar??
I'm still doing my designs on graph paper or Visio!!
CAD has always scared me :shock: :shock:
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby mikeschn » Sun Feb 18, 2007 3:55 pm
To run Inventor you need to initialize FlexLM and leave it running in the background while you start Inventor.
Images: 479
Postby Steve Frederick » Sun Feb 18, 2007 4:08 pm
mikeschn wrote:To run Inventor you need to initialize FlexLM and leave it running in the background while you start Inventor.
Got a disk with " Vault Client"
and "Data Management Server"
Looked for FlexLM, where would it be on the computer?
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby mikeschn » Sun Feb 18, 2007 4:14 pm
FlexLM has to be setup after you install Inventor. It should be on one of the CD's that came with Inventor.
When you find it, and run it, it'll look something like this...
Images: 479
Postby Steve Frederick » Sun Feb 18, 2007 4:58 pm
No files mentioning FlexLM on any of the 4 CD's!
Just "Vault", which seems to be a database engine for networks.
It does mention Internet Information Services though!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby mikeschn » Sun Feb 18, 2007 5:07 pm
Vault is a PDM (Product Data Management) package.
We can only assume two things here...
1) The student version doesn't need FlexLM, in which case your copy of Inventor should run. Did you reboot the machine after you installed it?
2) If the student version needs flexLM then you are missing a CD, or you missed a step when installing the program. You might want to try to reinstall the program keeping an eye out for the FlexLM portion of the program...
P.S. I'll search the web and see if I can find anything else.
Images: 479
Postby Steve Frederick » Sun Feb 18, 2007 5:12 pm
mikeschn wrote:Vault is a PDM (Product Data Management) package.
I'm thinking of the re-install!
I didn't install it the first time..just handed the ball as Lyn was heading for work!!
It's botched now, a re-install can't hurt?? Right?
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby mikeschn » Sun Feb 18, 2007 5:25 pm
Go for it!
Images: 479
Postby Steve Frederick » Sun Feb 18, 2007 5:46 pm
I attempted a re-install, but I'm running a repair first!
Thanks for the help so-far! I guess I'm not gonna get out to the shop today :cry:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby mikeschn » Sun Feb 18, 2007 6:58 pm
Sounds like there is a more serious problem.
Can you try it on another computer? If it works there, the first computer might need wiping.
It could also be defective CDs, in which case you'd have to get replacements CDs. Then again, it might just be the CD drive, in which case it might install just fine on a second computer.
Mike..
Images: 479
Postby toypusher » Sun Feb 18, 2007 7:51 pm
Steve,
Does the program have it's own uninstall program?? If so, it should be on the 'Start' menu and would work better than the 'Add/Remove' in the control panel.
You may want to go to their website and see if there are instructions to 'Manually' uninstall the program.
If all else fails, you can come down to visit me and I will get it fixed for you!! (We have alot less snow right now)!!!! :)
toypusher
Images: 324
Postby Steve Frederick » Sun Feb 18, 2007 8:01 pm
Re-install won't work..Get a "program not responding"..Tried a repair from the Remove/install program..same message!
I've been messing with this for 4-hrs! I dunno!! :x
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby asianflava » Sun Feb 18, 2007 9:38 pm
Here is a simple suggestion, does your computer meet the minimum requirements?
asianflava
Postby mikeschn » Mon Feb 19, 2007 5:52 pm
Any luck today Steve?
Images: 479
Postby Steve Frederick » Mon Feb 19, 2007 10:21 pm
mikeschn wrote:Any luck today Steve?
My son took the computer to school today. I haven't heard tho outcome yet!
Thanks for the help though, Mike! You-da-Man!! :applause:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Return to CAD secrets
