Podunkfla wrote:Hmmm... Angle steel is lighter. Square tubing is stronger. Both will work fine for you average small teardrop with a 3/4" plywood floor. Even a 1/2" floor is prolly ok with some 1 x 2" framing. when the whole box is assembled it adds quite a bit of strength so the frame doesn't have to be all that heavy. JMHO
For the same strength, a thinner box of the same metal (alloy, heat treatment) will weigh less than the angle alternative, and a C-channel falls somewhere in between, which is one reason why no vehicles other than inexpensive trailers are made with angle iron frames - it's not efficient.
