1) Is there a real value to the floor hatch? My wife and I are VERY short (remember that I said "very"), and I can't imagine that extra couple of inches making a big difference when doing our business on a porta-potty. As a matter of fact, I really can't imagine DOING that businesss in there most of the time anyway. (Markham Park has great toilets.) I ask this now because this affects a modification on the chassis.
2) Is it really impossible to cut off the extra length parts off the chassis with a hacksaw, or should I DEFINITELY use an ang;e grinder? I figured I would clamp the pieces to my redwood picnic table, so I imagine the pieces will remian pretty stable and not shigt around. I guess I have a basic fear of that angle grinder, because if I screw up, there goes the chassis.
3) What kind of wood did you use for the cross-brace? The plans say Dry Douglas Fir. Also, if the actual called-for dimensions are 1 1/2 by 2 7/8, what's that called in the real world? Like I know a 2 by 4 measures less than that, so what's the deal here?
4) The notches??? Duh??? Inside Flanges??? What's a Flange? Do they mean the inside part of the side rails? (Bottom of page 17).
Am I notching the 4 side rails (2 each side) where they meet in the middle to accept the wood cross brace? I don't get this, because looking at the way I cut the wood brace, it would seem it would fit in there anyway. I wish I could see a photo of this somewhere to see what we're talking about, and how the heck to do it. (Anyone out there still reading this who can point me to a page?)
5) The illustration shows a part with the text "Notch to clear axle." Is this something I have to actually DO, or is this just a test to confuse me? My guess is that this may have to do with modifying the axle position for the tongue weight, which I don't have to do because I'll be hauling with a truck. If I'm right here, can I just ignore this, and follow the trailor instructions?
IraRat wrote:Althought the length of that wooden member should be per plans, right? 47 3/4.
toypusher wrote:IraRat,
Have a look at this and see if it helps:
http://www.teardrops.us/userfiles/toypusher/HF%20frame%20mods%20copy.jpg
Kerry
