Moderator: Mike B
vrooom3440 wrote:Everybody has done a dump cake in a DO... maybe you have done this one or seen it already.
My favorite is the peach because it is just too easy. I have also done cherry/chocolate. But the scouts threw me a curve when they asked for a third cobbler at summer camp last year... what to do? what to do?
Somebody suggested apple. Sounds good but you cannot buy canned apples in juice like you can peaches and cherries. But necessity is the mother on invention so here is what I came up with:
Using 12" DO:
8-10 fresh apples cut up into ~1/4" slices unpeeled (I used Fuji)
Some amount of apple juice so about 2/3 of apples are swimming.
Sprinkle liberally with cinammon.
Dump spice cake mix over apples, do not mix just level.
Apply about 1/2 cube of butter over top in pats.
Sprinkle MORE cinammon.
Close'r up and cook for 30-45 minutes like any other dump cobbler. Good stuff [/i]
vrooom3440 wrote:Pie filling may work... but I try to go with lower sugar content especially on the bottom. As the sugar content goes up so does the probability of scorching. Or that has been my experience.
The other factor, I believe, is that you need to create some steam to make the cake mix work. Using a fruit juice provides this steam and turns in to a flavor concentrated reduction during cooking
You can probably offset the lack of water in the pie filling by dumping in a can of 7-Up or something as is done in many recipes.
Kevin A wrote:
I've used it numerous times for DO dump cakes.
doug hodder wrote:
Blasphemy Kevin!!! Since I live up in an area known as "Apple Hill" and people drive up here all the way from the Bay area in the fall to get fresh fruit from local growers....well, I just gotta go with them. Doug
doug hodder wrote:Flatlanders.....what can I say! Rich...I'll try to get some good pics of them chaining up this winter....good for a few grins! Especially if I'm doing/ enjoying DO cobbler while they do it. Doug
Miriam C. wrote:Any reason you can't remove some of the thick filling and replace it with juice or pop? I tried one with cherry coke and chocolate cake mix.........Great brownies. Was a bit damper than I wanted.
Users browsing this forum: No registered users and 23 guests
