doug hodder wrote:For any of the parts....carb cleaner will get off all the carbon, works on stainless also...and if you soak the brass pieces in white vinegar and then hit it with some 0000 steel wool and a little polish...they look good as new. Be careful on the little wire tips. Only wipe those parts in 1 direction so as to not bend the tip, or you might be buying one in the future. Just an idea. Doug
doug hodder wrote:Full strength...just watch, you'll see it start to work. I leave them in for a couple of hours. Doug
fastED wrote:..... I just got a Coleman 200a lantern, and it has a 'surging" in it's brightness when it is running. I changed the fuel twice, so the fuel is fresh. I'm thinking either a bad generator, or an air leak somewhere. Does any of you have a suggestion? I will probably replace the generator regardless.
