by ArkansasDon » Wed Feb 12, 2020 7:50 am
water crossings should be taken seriously, the approach & the exiting, I never cross fast or deep water. When I was researching small squaredrop trailer manufactures (looking for a candidate to do a offroad squaredrop build) I liked how Runaway has a rubber membrane underneath the floor, the cabin (under construction on video) all the corners are wrapped before the adhesive & aluminum siding is attached. Runaway's method of attachment of the cabin to the chassis is also very impressive making it for good waterproof system.
When I done all the modifications & fabrication work to our 2019 Range Runner, ground clearance of chassis was 24", axle clearance was 14". Sally & I make numerous creek crossings on our backcountry adventures in the Ozarks. We never had any water inside the cabin or rear storage area nor leaking from the inside of the chassis. I periodically check the chassis for rust, rear storage area for water staining. I store the trailer inside a large shop building on my farm.
I used automotive sealant between the aluminum siding lower edge & bottom edge were the cabin & chassis meets (Black). When I re-placed the tail lights & re-wired the trailer lights, attaching the wires (fasteners) to the underneath floor to the membrane & chassis I sealed these areas extremely well with sealant. All accessories attached to the outside of the squaredrop 2 1\2gal Roto Fuel Pax, 2 1\2 gal Roto Water Pax, Hi Lift Jack Mount I made rubber gaskets & using sealant (Big Stretch) with large fender washers & locking nuts. Water will find a way into areas you do not want it to go. So far I've been lucky or successful not having any water leaking into areas of the trailer. Maintenance is a must, checking on the sealant applied, water can & will ruin a wood structured trailers.
Next month Sally & I are leaving on another 2 state Trans American Trail adventure, it's made up of dirt, gravel, forest, farm, & brief sections of paved roads. Were taking 10 days to do this with many stay overs.
- Attachments
- forum (6).jpg (215.94 KiB) Viewed 4560 times
- 007.JPG (134.92 KiB) Viewed 4560 times
- 003.JPG (133.27 KiB) Viewed 4560 times
ArkansasDon on Wed Feb 12, 2020 11:42 am, edited 1 time in total.
