+2 on the laser envy.
On the project list, after build #2, I had in mind to build a sheet goods size CNC router, but I would have to convince the CFO, that I can have both halves of the garage.
Txbum wrote:Hola, felicidades , has hecho muy bueno en la construcciones . Orale dale con mas ganas! Txbum
2bits wrote:Oh yeah you made some good progress alright! I think the height of your AC is in a good place and I like those lights! ! What are you gonna use to cover the AC Box on the outside when on the road?
Dean_A wrote:Looks like it's really coming along! You might want to double check the location of the screw holes for your roof vent/fan. I know on some models (i.e. Fantastic Fans) the single roof spar isn't wide enough to screw into. I had to add some blocking around my fan opening.
