mechmagcn wrote:Hmmm.... I've got a customer with a ice machine that holds up to 500lbs. That's where I usually get most of my ice from
Ageless wrote:Most of the high end motels have the ice units secured. You have to have a key-card to get ice
Shadow Catcher wrote:I did a test once using our indoor outdoor thermometer, and have since tested our home freezer. Temperature inside the bag ice machine at the store was 30 degrees inside our freezer at home 0 degrees, with the ice maker on it is -20. What you start out with has a lot to do with how long it lasts.
Does any one have an internal temp reading on one of the table top ice makers and the current draw? When plugged in it may well be an idea.
planovet wrote:caseydog wrote:I have an icemaker in the freezer, and I freeze bottles of ice for my cooler for camping, but if I need a bunch of ice cubes, I got to 7-eleven and buy a bag or two.
That pretty much does it for me too. I try to make it not too complicated.
