Trailer Tire Pressure Question
Postby larryl » Mon Nov 07, 2005 10:11 am
My 5X8 carry-on trailer uses a 4:80 X 12 tire. The manufacture suggests
a tire pressure of 90 PSI/cold. This seems high to me. What pressure are most of you using for your tires?
Larry
larryl
Images: 22
Postby bledsoe3 » Mon Nov 07, 2005 11:36 am
That much air pressure seems like it make your tear bounce alot.
bledsoe3
Images: 112
Postby Nitetimes » Mon Nov 07, 2005 12:18 pm
I'd try it between 50 & 60lbs. If it doesn't let the tire squat there you may be able to go a little lower. You just don't want to get them to where it looks like they are low on air.
I never run tires at their max pressure unless I have a heavy load, it isn't really necessary.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Arne » Mon Nov 07, 2005 1:44 pm
I kept dropping mine 5# at a time till the tires got warm, then went up 10 psi... wound up at 40 psi on the 1,800# trailer.... rides better...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby roger-c » Mon Nov 07, 2005 10:53 pm
I run my 1800lb 13" tires at 35lbs and I had no problems.
Roger C.
Don�t force it use a bigger hammer!
roger-c
Images: 9
Postby angib » Tue Nov 08, 2005 7:17 am
Here is the load/pressure chart from Carlisle's web site:
It's a bit disappointing that, as they sell smaller trailer tires, they don't give any data for them.
It might be worth pointing out that the load above is load per tire - double it for load per pair.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby randy chesnutt » Tue Nov 08, 2005 8:24 pm
by having your trailer weight and go to the chart like andrew posted for your tires will tell you what the pressure should be. if you weight it make sure that it is loaded like it would be if you are going on a trip. you need to have each wheel weight . that way you will know if you are heavier on one side or the other. it's like my motorhome i had it weight. every wheel had it's on scale. when i got my weight on each wheel and i found out that i was about the same weight on both side which was good then i went to the tire chart and reset my tire pressure. you may think that it's just a small trailer but it doesn,t make a differrent. but it does. to much weight on one side can effect the pulling and puts alot of weight on that tire.
randy chesnutt
Images: 65
Postby TonyCooper » Mon Nov 14, 2005 12:32 am
arnereil wrote:I kept dropping mine 5# at a time till the tires got warm, then went up 10 psi... wound up at 40 psi on the 1,800# trailer.... rides better...
This is good information. It will save me some time . Thanks!
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby Arne » Mon Nov 14, 2005 6:52 am
Tony, I've not tried this, but might for the fun of it..... let air out till you notice a change in the shape where the tire sits on the ground (ie, buldge) and see what pressure you have then. It would give you a minimum pressure, then you could start say 20# above that......
But I think mine had a sidewall pressure of 65# and it bounced quite a bit. Not dangerous, just every little pebble or road joint gave it a little jiggle up and down.....At 40 psi it is more user friendly.
Arne
Mr. Subject Line
Images: 96
Postby TonyCooper » Tue Nov 15, 2005 4:23 pm
I'm going to attempt to stay and use the 12" trailer tires that came with the HF frame. I even purchased a spare... But if it gets crazy bouncy I'll upgrade to 12" steel belted radial tires for a better ride...
Better safe then sorry!
I am targeting a run from Raleigh, NC to Montgomery, AL to meet my sister for Thanksgiving Day. I'll know early on how well it pulls and handles... This first pass is with the Ranger 4.0. After I get back it's "try it with the miata time"
I'd better hurry..still have a hatch to build and install!
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby LSmith » Sat Nov 26, 2005 10:45 am
The original tag on my KIT indicates 12 - 15 psi. I have 16" wheels/tires and it keeps the tear from bouncing ....seems to work well, very little weight so that is not a real factor
LSmith
LSmith
Postby traveler » Tue Jun 10, 2008 10:32 pm
I put 40 lbs in my trailer tires and 45lbs in my rear TV tires and 35 lbs in the front tires of the TV.
Why do anything unless it is fun with your teardrop
traveler
Return to User Polls
