A Stainless Steel Dutch Oven
Postby Prem » Mon Apr 19, 2010 2:52 pm
A 3.5 qt. Stainless Steel Camp Dutch oven
Got the SS thick bottom pot for $1 at the swap meet. The lid is a heavy baking pan that I found at the Goodwill for $1.69. The aluminum handle and #6 SS bolts, washers and cap nuts I already had. (The lid also fits my 12 quart SS thick-bottom stock pot if I want to use it with charcoal briquettes above and below to make a big batch of soup faster. ) :? :twisted: ;)
Marking the holes to drill for the handle was a bit tricky, but it looks like I got the handle in the center.
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Rock » Tue Apr 20, 2010 8:00 am
Very cool but keep in mind that SS is a crappy conductor of heat compared to CI. I'm sure it will work great but you need to experiment a little with the coals.
Eric
Rock
Images: 48
Postby Prem » Tue Apr 20, 2010 11:04 am
Yeah, but there's a disk of aluminum in the bottom clad with thin SS on both sides on this pot. It heats faster than my 12" inch cast iron Dutch oven.
That baking pan lid is heavy for a pan, but light for a lid. I think I will cut a circle of aluminum diamond plate for an insert on top (flush and under the handle) so that it adds more mass and a protective, replaceable layer of metal between the coals and the pan surface. :twisted:
Lots of fun.
Prem
P.S. Nice teardrop you built Eric! :thumbsup: Polyester or epoxy resin over the glass?
My goal...
Prem
Images: 144
Postby Rock » Tue Apr 20, 2010 2:57 pm
In that case that might be the ultimate DO. Yeah - a 3/8" piece of aluminum inside that lid will make the heat radiate down nice and even. Looking good.
Eric
Rock
Images: 48
Postby Prem » Tue Apr 20, 2010 7:14 pm
Good call! 3/8" is about the thickness of the bottom of the pot with the aluminum disk in it.
I'm going to the scrap metal place tomorrow. I'm gonna get smooth 3/8ths instead of diamond plate.
Must find a very fine tooth, metal-cutting jigsaw blade (or two or three) for this job. The diameter of the inside of the lid is a shade under 9 inches, so that's 27 inches of cutting the circle.
My goal...
Prem
Images: 144
Cutting aluminum
Postby eamarquardt » Tue Apr 20, 2010 7:34 pm
I have found the trick to cutting aluminum is keeping it as cool as possible. When it heats up it gums up and sticks to the blade filling in the teeth. When this happens, your effort is doomed untill you pick the al out of the teeth of your blade. If you have someone spray water on it with "windex" sprayer while you cut, you will have better results. I often run the garden hose over the sheet (I have a lifetime supply of 1/8 sheet that I am slowly using up) right where I'm cutting and that works great (you gotta trust your double insulated tool and GFI if you wanna do this and you can't get over zealous with the water flow).
Good luck.
Cheers,
Gus
eamarquardt
Images: 150
Re: Cutting aluminum
Postby Kevin A » Tue Apr 20, 2010 7:37 pm
eamarquardt wrote:I have found the trick to cutting aluminum is keeping it as cool as possible. When it heats up it gums up and sticks to the blade filling in the teeth. When this happens, your effort is doomed untill you pick the al out of the teeth of your blade. If you have someone spray water on it with "windex" sprayer while you cut, you will have better results. I often run the garden hose over the sheet (I have a lifetime supply of 1/8 sheet that I am slowly using up) right where I'm cutting and that works great (you gotta trust your double insulated tool and GFI if you wanna do this and you can't get over zealous with the water flow).
Good luck.
Cheers,
Gus
Either that or use a battery powered jig saw. Better yet, air powered.
Kevin A
The other guy
Images: 289
Postby Rock » Wed Apr 21, 2010 4:37 am
Hey Prem - missed your question on my tear. I used System 3 throughout, with Silvertip Laminating resin for all coating and glassing. Just getting around to sanding it right now for a topcoat of a linked polyurethane.
Yeah - without industrial tools that will cut slow. Just gotta take ur time.
Eric
Rock
Images: 48
Postby Prem » Tue Apr 27, 2010 6:40 pm
Eric,
That's the way to do it right. You da man.
Prem :thumbsup:
My goal...
Prem
Images: 144
Postby Prem » Tue Apr 27, 2010 6:49 pm
:thumbdown: I really don't like cutting aluminum with a blade, so I went looking for *something* else. I figured thin SS would never burn through, but I have never had any SS sheet that was thin enough to cut with hand sheers. Today I found the perfect solution at the Goodwill for a buck. It was a Korean SS frying pan, thin but with a copper bottom. I figured it was right at the limit of thickness to cut with my big, accurate metal sheers. Sure enough, it worked! :D
The scrap to the left is the sections of the side of the fry pan that got cut away.
The perfect fit left just a little of the up flip of the original fry pan interior. That makes it even better for use with hot charcoal. The other plus is that when I drilled it and put the handle back in the center of the lid, the insert sucked right down flush all the way around. :)
Sometimes things go right.
Total cost: $3.69 (And about $10 in gasoline. lol.)
Prem
My goal...
Prem
Images: 144
Postby Mark72 » Tue Apr 27, 2010 9:25 pm
So its time for pics of it in action right?
Mark
Mark72
Images: 127
Postby Prem » Tue Apr 27, 2010 10:18 pm
That will have to wait for the weekend at the 17th Dam Gathering. It's pouring rain on and off all day thru Thursday here.
My goal...
Prem
Images: 144
Postby Prem » Sun May 30, 2010 9:40 pm
Mark72 wrote:So its time for pics of it in action right?
Coconut-Raspberry-Chipotle-Ground-Turkey and Turkey Sausage Stew with Potatoes, Carrots, Celery, Cilantro, Onions and Garlic
Turned out *REALLY* tasty and nothing burned on.
(Next dish I cook in it I will increase the quantity by 3 or 4 times.)
My goal...
Prem
Images: 144
Postby Mark72 » Mon May 31, 2010 8:25 pm
Mark72
Images: 127
Return to Cast Iron
