rainjer wrote:
Ok, a couple questions.
How thick are the floor in the pockets where you routed?
3/8"
Are you going to skin the outside with aluminum?
Yes
What are you going to use on the inside to cover the honeycomb?
3/4" blue board/foam sheets
Are you gong to fill the honeycomb voids? If so, with what?
blue board, but I will need to figure that one some more.
Jeremy
mikeschn wrote:I think it's a good idea, albeit a lot of work.
rainjer wrote:Based on you answers I would bet if you went a 1" X 2" frame and did a sandwich of .040" aluminum + 1/8" plywood (or 1/4") +frame with foam in the voids + 1/8 plywood you would end up with a lighter construction, just as strong and a lot less work.
You could also CNC you frame out of 3/4" plywood ans make the frame in 1 piece.
Jeremy
If you are skinning it with plywood, inside and out, you don't need all that honeycomb stuff in there. Just a few structural members, and some EPS.
like this...
like this...
Users browsing this forum: Google [Bot] and 1 guest
