The Dog House *It's done!!!! 6/20/2015"
Postby Juneaudave » Sun Oct 03, 2010 3:49 pm
:thumbsup: Looks good! :thumbsup:
Juneaudave
Images: 380
Postby jss06 » Wed Oct 06, 2010 1:45 pm
Now that I have almost finished my frame. It's time to start thinking about the body.
I put a boring meeting to good use today. :D I think this is how I am going to do my walls. I work better in free hand than I do in CAD.
jss06
Palladium Donating Member
Postby aggie79 » Wed Oct 06, 2010 4:25 pm
John,
Your trailer looks outstanding. You are really on a roll.
Postby jss06 » Sun Oct 10, 2010 3:54 pm
Frame almost 100% complete. Spent the weekend putting on the frame extensions. At least now it does not look like its 40ft long behind the Jeep.
I used a large piece of scrap plywood and a clamp to give me a stable surface to fit and tack weld the frame extensions.
Everyone should have one of these in their shop
Eveything together. Looks a lot shorter now.
I left the box for the rear cross member open and added a piece on the passenger side just in front of the tire to give me a place to mount accessories in the future.
I still have to do the body mount tabs and the tongue braces. My plasma cutter is down waiting on a replacement part so I cant shape the tongue braces yet.
jss06
Postby PhotoGuy » Mon Oct 11, 2010 7:53 pm
looking good. cant wait to see more :thumbsup:
PhotoGuy
Postby jss06 » Fri Oct 15, 2010 4:43 pm
Decided to mount the jack inside the A-frame. If I want to move it later I just need to spend a couple of bucks for another piece to weld to the frame.
Time to start making sawdust.
Bought a rack for the Jeep to allow me to get lumber without borrowing a pickup. It's made by Olympic 4x4 and works great.
Getting ready to lay the keel. Most of the wiring will run through the floor instead of through the walls or ceiling. More to come later.
jss06
Postby steve smoot » Sat Oct 16, 2010 4:56 am
Wow, you are off and running. It looks great. Wish I could weld like that. :thumbsup:
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby jss06 » Sun Oct 17, 2010 2:18 pm
Spent some more time in the garage today. Have the main layout of the floor complete. I don't want to go any further until the frame is completed and painted.
Cut and fit the main floor panels.
I routed and overlapped the panels to make the floor act as a single piece.
The tongue box will be integrated into the body. So I used the same technique for joining the panels. I used a hand chisel to square off the corners of the routed area.
Fits like a glove
Shaping the floor of the tongue box.
And all together.
Still have to glue everything together. That will have to wait until the frame is completed and painted. I should have the replacement part for my plasma torch tomorrow so I can finish the frame construction this week.
jss06
Postby jss06 » Sat Oct 30, 2010 3:23 pm
Finally got the parts for my plasma torch so I can finish the frame and get it ready for rhino lining.
Started by fishmouthing the tongue support braces.
Cleaned up the cuts and closed the mouth.
Welded the mouth closed. This will provide a ramp to help pull the frame over obstacles.
Mounting the braces.
Now I can at last take it down to the shop and have it rhino lined. Then I can get back to work on the body.
jss06
Postby myoung » Sat Oct 30, 2010 6:10 pm
Interesting touches. I'll look forward to more.
Mike Young
myoung
Images: 250
Postby jss06 » Wed Nov 17, 2010 2:06 pm
Picking up the frame this evening after work. Had it rhinolined to help protect it.
jss06
Postby aggie79 » Wed Nov 17, 2010 3:52 pm
Very cool John!
I had my frame built and even though they used "new" steel, it was a bear to finish/paint the frame. I think getting it coated is the way to go.
Postby jss06 » Wed Nov 17, 2010 7:25 pm
Couple of pics. This stuff even makes my welds look good. :lol:
Now I can start working on the body.
jss06
Postby Cliffmeister2000 » Wed Nov 17, 2010 11:03 pm
jss06 wrote:
Take it back! They got fingerprints on your springs! :?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby aggie79 » Thu Nov 18, 2010 9:16 am
John -
Your frame looks great. You've got a great platform to build upon.
