Watch out for Sketchup 7.1
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby pebo » Thu Oct 08, 2009 7:37 am
I draw in 3D using Autocad LT (which is not actually 3D software) then use Sketchup to import and model my drawings and have been doing this for almost as long as SketchUp has been around. This past week when I opened Sketchup it ask if I wanted to upgrade to 7.1 not thinking anything of it, I went ahead and did it. When I went to import my current .DWG file I found that Google took the import for .dwg and .dxf out of the free version of SketchUp. When I went to the Sketchup site and looked I found that you now have to buy the Pro version for $495 to get the option of importing .dwg and .dxf. files. Luckly I had originally downloaded the 7.0 file so that I was able to unload 7.1 and reload 7.0. Just something to keep in mine if you use SketchUp just for modeling. I probably should try drawing in SketchUp but have been drawing in AutoCad since version 1 on one of the first DOS machines. It's a comfort thing I guess.
pebo
Images: 22
Postby starleen2 » Thu Oct 08, 2009 8:01 am
Thanks for the heads up on this!
starleen2
5th Teardrop Club
Images: 206
Postby steve smoot » Fri Mar 19, 2010 6:12 pm
Hi guys,
I have the free version of Google Sketch up, and I have created a 3D drawing of the camper I want to build, but I can not figure out how to get the drawing over here to the forum... :thinking: Can someone explain how to do this?
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby starleen2 » Fri Mar 19, 2010 9:55 pm
steve smoot wrote:Hi guys,
There are two ways of doing this
1. create a 2d drawing with the export feature under the "File" menu. choose your size to export and it will create a JPG file that you can upload to your album(or photobucket, other picture hosting service) then regular forum picture posting method wrapped in brackets applied
2. upload it to the 3D warehouse, and post link
starleen2
5th Teardrop Club
Images: 206
Postby steve smoot » Sat Mar 20, 2010 4:46 pm
Thanks for the info Mr S. Stewart. I will give it try later tonight and see what happens. :worship:
steve smoot
Images: 62
Postby pete42 » Tue Apr 13, 2010 8:29 am
I posted over in general post section I can not get the 7.1 version to give me measurments on the drawing like I could using 7.0
can someone send me a copy of 7.0 thanks.
pete42
Postby txturbo » Sat Mar 19, 2011 6:51 am
txturbo
Postby Ron Dickey » Fri Apr 22, 2011 1:59 pm
it seems ezy to use.
it helps to print out the quick reference card so you know what does what.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby pebo » Sun Apr 24, 2011 8:30 am
I now use version 8, but loaded it in a different folder keeping version 7. This way if I want to import anything from AutoCad I do it in 7, then open that drawing in version 8.
pebo
Images: 22
Return to CAD secrets
