Dale M. wrote:Why do you think its necessary to have two systems.... Keep it simple.... Just use city water to fill tank and use pump to supply faucet...
Dale
Larwyn wrote:RV water pumps usually have a built in check valve on the pressure side to prevent back flow into the fresh water tank. When you see a large puddle under an RV it is often due to failure of this check valve which allows city water to over flow the tank. There is also a check valve built in to the city water connection which prevents water escaping at that point when using the on board water system.
On my 5th wheel, I installed a ball valve to bypass the pump so I cold fill the fresh water tank from the city water connection. I just had to remember to close the valve once the tank was filled. This saved a lot of hassle since the city water connection was on the back of the trailer and the fresh water fill was located on the front.
dh wrote:Larwyn wrote:RV water pumps usually have a built in check valve on the pressure side to prevent back flow into the fresh water tank. When you see a large puddle under an RV it is often due to failure of this check valve which allows city water to over flow the tank. There is also a check valve built in to the city water connection which prevents water escaping at that point when using the on board water system.
Larwyn, could you post a diagram, I like the idea of filling from the city water connection.
bobhenry wrote:If I am understanding correctly.......
