Shadow Catcher wrote:RV water heaters have a bottom drain. You should NOT use the pressure relief for any other purpose period it is there for a reason. I do not know what the construction is but you might be able to install a drain unless it is lined.
GeoDrop wrote:I have the same heater and we just completed our first camping trip. I really think we only have two options: 1) remove a connection and siphon out the water, which I did over the winter or 2) run fresh water through it once a month or so.
As to the siphoning.. you could get creative and put some sort of y-fitting with a valve that you can open/close that would allow a small tube to be inserted down into the tank and siphoned out. Just a thought anyway.
I was looking to add this unit on my trailer. Perhaps the best solution is to have quick disconnects for all connections and remove the unit and drain by turning upside down.myoung wrote:There are three openings to the hot water tank: a cold water inlet, a hot water outlet, and a pressure relief valve.
This is all well and good for a hot water heater that is used every day in a home bathroom or kitchen. But, what about periodic use in an RV?
I don't welcome the thought of water sitting stagnant in the tank for days, weeks, or even months between camping trips. So, what to do. Surely there must be some way to drain the tank by adding another opening to the tank itself, rigging some siphon or pump, or repurposing the pressure relief valve to a tube for either siphoning or pumping.
Does anyone have experience with this contraption and the problem of draining the tank? Any and all suggestions would be most welcome.
Thanks in advance.
myoung wrote:Shadow Catcher wrote:This is not a standard or typical RV hot water heater. It is designed primarily for a home installation.
The pressure relief valve is designed to work at 150 psi, which is far higher than pressure possible in my installation with a 40 psi regulator on the shore water feed and an electric pump on the fresh water feed.
Thanks.
myoung wrote:GeoDrop wrote:I have the same heater and we just completed our first camping trip. I really think we only have two options: 1) remove a connection and siphon out the water, which I did over the winter or 2) run fresh water through it once a month or so.
Matthew & Sandi,
Do you know if the siphoning removed all the water or just some of it?
GeoDrop wrote:By the volume of water that came out, I would say most of it.... hard to get it all without turning upside down.
I'd be interested is finding/seeing these 'quick disconnects' that someone mentioned.
