So a mini tank unit all electric like these will not fill the bill? The 2.5 gal. one is 14" x 14" x 10"2bits wrote:I just spent a couple of educational hours searching, but it seems that all the stuff I am running into on the forum/eBay etc are "outdoor" tankless water heaters. I am going to put a shower in my next trailer and prefer to have a tankless water heater in a cabinet rather than hanging from a tree or bolted to the outside of the trailer. I would like to screw a water hose into the side of the trailer and be done with it. I have decided against Solar or alternate water delivery or storage ideas. Just looking for one of those wonderful units that I see everywhere but can be mounter indoors.
Anyone have suggestions or a link? Propane or Elec and at or under $200 would be great! (Experience with said item is even better!)
Thanks!
Oh I get it now. You have already been using a 6 gal tank and you would like to increase your capacity by a tankless unit. Well this is actually very interesting to me. I was thinking of using a 4.5 gal unit and now you have me wondering just how much of a shower is possible with that if you are thinking that a 6 gal is not enough.2bits wrote:Thanks for the replies! Madjack, I like the way you cut to the chase. That helps alot and I guess I am going to have to rethink my ideas a little! Since it is just me the 6 gal tank heater might not be too bad, and I will give the outdoor mounted one another thought. I wonder if it would work inside a vented box on the tongue? I wouldn't mind putting huge vents in it, I just was thinking about covering it up just for the look of it...
