Homemade custom cooler?
Postby BillZ » Mon May 23, 2011 11:27 pm
I'm having trouble finding a cooler that will fit below my counter. The space is shallow. I need something that is no more than a foot high and a foot deep. A thought occurred to me that maybe I can make a custom cooler.
My thought is to make a wooden box to fit, put a plastic tub inside and insulate in between the 2 containers. The lid could be tricky but seems doable.
Has anyone done something like this?
I have thought about it.
Postby tlcofomaha » Tue May 24, 2011 8:09 am
I have loosly planned a couple out in my mind. You could wind up with one of those EXTREME coolers if you use thick foam. As long as you get a decent seal around the lid it will work great. I knew a guy once that built a large cooler/box out of 2 inch styrofoam and covered it with fiberglass. I dont remember if it even had a lid but it would keep a keg cold all weekend.
Postby slowcowboy » Tue May 24, 2011 9:37 am
mine is simaler going below the counter top but I found one that would fit. its just getting a box around the exsisting cooler and more foam insulation and getting turned into a built in ice box.
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
6000 Club
6000 Club
Images: 166
Postby Arne » Tue May 24, 2011 8:19 pm
Some of the best coolers I've seen are made out of 2" rigid foam insulation... they hold ice for a very long time.
Mr. Subject Line
Images: 96
Postby atahoekid » Wed May 25, 2011 12:11 am
I found an article on-line a while back about a guy who made a cooler out of epoxy and fiberglass for his boat. Sounds a bit more complicated than your idea or the foam board insulation idea but it was water tight
Images: 158
Postby GPW » Wed May 25, 2011 7:29 am
Billz, you might want to check out the Foamie threads... we're building all sorts of things with foam ...Custom Cooler would be easy ... :thumbsup:
Images: 544
Re: Homemade custom cooler?
Postby Dan242 » Mon Jun 12, 2017 11:51 pm
Bringing back from the dusty archive, first thread I could find,
I built a below floor storage compartment I think I'm gonna turn into a cooler. Its about 24" by 16" and slopes from about 10" deep to 16" . I have sheets of 3/4" styro, gonna layer them in, then sit a plastic tub and trim the top. There will be a gap, I am thinking of shooting in expanding foam to fill in the gaps, in couple of layers to let it expand. I have a ply wood lid that I will glue a layer of styro to to fit inside box, will be a flat lid all the way around with a thin rubber gasket to seal. Thinking 1.5 to 2" of foam most of the way around. Weight will be right behind the rear axle, down low, easily offset by a 5 Gallon jerry can of water on the tongue. Is there a better brand of expanding foam for getting the most expansion? Thinking this will be mostly to have ice in for drinks over a weekend, or maybe top off another cooler as needed. Not sure if I need a drain or not, maybe a small plastic siphon pump or suck it out with a straw (drinking water!) What say the Hive?
Images: 24
Postby working on it » Tue Jun 13, 2017 8:20 am
I've just completed doing a similar project, by using two existing coolers, rigid foam, Great Stuff, foil duct tape, and EPDM foam tape. I was trying to use the composite? cooler (one Cube cooler inside a larger Cube cooler) to fit in the small space. Initially, I just used the larger Cube cooler, but it wasn't keeping my perishable foods cold enough for even a three-day trip, so I thought I'd try making it more efficient. I had mediocre results, but haven't given up, yet. Here's the thread : http://www.tnttt.com/viewtopic.php?f=2&t=68543
2013 HHRv"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • 3500 lb Dexter axle w/brakes,
  • 27x8.5-14LT all-terrain tires,
  • LED lighting in/out,
  • A/C & heat, Optima AGM battery,
  • extended-run 2500w generator,
  • Coleman dual-fuel stove & lantern,
  • galvanized/stainless steel front rack
working on it
Images: 428
Postby Dirtclod » Tue Jun 13, 2017 10:57 am
Seems like a Great Idea and one of a kind.
In fact Timberleaf Trailers even offers one as an option:
Images: 9
Postby Trebor English » Tue Jun 13, 2017 7:44 pm
I made a cooler. The outside is a 49 quart Rubbermaid tub. The inside is a 12 quart Rubbermaid tub. Between the two there is 2 inches of 1/2 inch polyiso sheet cut to fit. The 12 quart holds 10 pounds of ice and a 9 x 13 aluminum baking pan that sits on top. The food stays dry in the aluminum pan. The lid is 1 inch poly and the 49 quart lid. It keeps ice 7 (June) to 10 (January) days. Without the 9 x 13 pan it would be good for drinks for a weekend. Spray foam Great Stuff would be a lot easier, cheaper, and probably better insulation.
Trebor English
Postby tac422 » Wed Jun 14, 2017 6:58 pm
I made a cooler out of 2" foam ...
details here :
Images: 218
Postby PanelDeland » Sat Sep 02, 2017 1:14 pm
Order a Ham. From Honey Baked to be delivered. They come in a box with a foam cooler inside (lid and all). The problem is that the cooler isn't structurally sound and needs the box or it will break, but, building a box for the Styrofoam cooler shouldn't be a stretch for the people who build trailers. Just build a smaller one to fit the cooler if you have problems. BTW They also come with a handy reusable ice pack, for the sore muscles from building it and for keeping it cool.
"I know the voices in my head aren't real,but they have some really good Ideas!"
Users browsing this forum: D-J Wade and 5 guests
