They make shower/toilet pans as small as 24"x34", so I would say that is about as small as one can go with a combo. I used this minimal dimension in my shower/toilet room. I won't kid you it is tight. I would think this is about minimum for toilet without shower as well.kirkman wrote:I thought I would ask this question because it would make for a great sticky! So how big do you think a potty closet needs to be. With and with out a shower.
You and me both! Thanks. I am at the half way point and taking a breather to make some design modifications before the next big push to finish my "Not A RV".kirkman wrote:Thanks! Your TTT Looks good I cant wait to see it finished!
Your right, 28" x 36" would be ideal. In my trailer everything is 2" short of ideal.mikeschn wrote:According to my notes, 28" wide by 36" long would be a very comfortable bathroom. While you could go smaller, you start to lose comfort.
We had a trailer with a 24" wide bathroom, and we could barely move!
So are you pooping in front of someone or is that person leaving the trailer? Sorry to be so blunt but I have not used such an arrangement and I know no other way to ask it.mikeschn wrote:I agree with Andrew...
That's why the porta potty in the standie foamie is positioned like this!
I did not realize that it was only used for "#1". See it is good I asked a blunt question because I would have never known. In my house we have an unwritten "door closed" policy for both numbers.mikeschn wrote:Well, for starters, it's for #1 only.
And the other person will either be laying in bed, or outside.
angib wrote:It's a while since I've posted this animation so here it is again.
The thing with potty rooms is that most of the space is completely useless for 99% of the time. One thing to consider is how to use the empty space (ie that bit not occupied by the potty itself) when it's not in use.
This idea is a straight copy of the arrangement we had in a boat when I was a boy. The door has a second leaf that folds out again to enclose a temporary room. It worked brilliantly though it might need a bit of adaptation to work so that you can go into the potty room at night.
