dh wrote:I found a 5lb propane tank for $5.00 at a flea market, and brought it home. I cracked the valve, and it has no pressure in it, and is rusted a bit. Where am I going with this? I am going to assume it was neglected, period. I know it needs purged, and I want it inspected before it goes back into service, and would like to re-paint it. Will this be cost efective, or would I be bettr off throwing $90.00 at new one?
dh wrote:That wasn't a typo in the OP, a 5lb tank, not a 5 gallon tank. Find a MANCHESTER 5lb tank new for under $75, and I'll take it.
It doesn't need the valve changed out, and I can handle the re-paint, but how much is an inspection and purge?
The tank is dated 2006, so maybe I can just inspect for intrnal rust while I have the valve off while refurbishing tank.
dh wrote:Looks like I can skip the inspection, make sure it isnt rusted inside and get purged and be good to go. The $90 is for a new tank, purging, first fill, and a 'complimentary' soap test, $75 just for the tanks, which isn't that much more than Dale's prices after shipping. How much pressure can a tank take? I'd like to pressure test the valve myself before I get it filled. I can put 150lbs of air pressure on it at home.
Larry C wrote:dh wrote:Looks like I can skip the inspection, make sure it isnt rusted inside and get purged and be good to go. The $90 is for a new tank, purging, first fill, and a 'complimentary' soap test, $75 just for the tanks, which isn't that much more than Dale's prices after shipping. How much pressure can a tank take? I'd like to pressure test the valve myself before I get it filled. I can put 150lbs of air pressure on it at home.
I believe the relief valve is set at 350. If that's the case, it probably has a 5 to 1 safety factor. Burst would be above 1750. However, I may be totally wrong on this.
Larry C
Dale M. wrote:Larry C wrote:dh wrote:Looks like I can skip the inspection, make sure it isnt rusted inside and get purged and be good to go. The $90 is for a new tank, purging, first fill, and a 'complimentary' soap test, $75 just for the tanks, which isn't that much more than Dale's prices after shipping. How much pressure can a tank take? I'd like to pressure test the valve myself before I get it filled. I can put 150lbs of air pressure on it at home.
Larry C
I had a propane tech at local place where they test and refit tanks tell me 260psi..
Oh well...
Larry C
Oh well...
dh wrote:I've read about this while researching the recertification process. As steel prices went up, tank wall thickness went down, as did the pressure rating.
Larry, when you hydro test a hose, how much pressure do you put on it?
