teardrop with loo for a tall person - impossible?
Postby jaffa » Sat Feb 04, 2006 4:42 pm
I'm looking for a tiny trailer, to fit a 6ft 6er - and it needs to have a loo impossible?
The best i've found is the adria action bit of a teardrop hybrid and 2x the price.
or a tab teardrop but it's a portapoty in a cupbord - not ideal,
can anyone sugest anything helpfull or should i give up?
:cry:
jaffa
Postby cracker39 » Sat Feb 04, 2006 5:20 pm
Porti potti in a cupboard? Hmmm...that sounds like my TTT design. Only it's in a low cabinet that will be used to sit a cooler on when camping. I'd like a toilet with holding tank, but that's getting outside the who KISS principal behind these TDs/TTTs, and more weight and expense. At least, I will have a Loo of sorts. At our ages, my wife and I would be trippin to the bathrooms all nite if we didn't have one.
Dale
cracker39
Images: 233
Postby 48Rob » Sat Feb 04, 2006 5:35 pm
Jaffa,
'Nuthin's impossible :thumbsup:
With a port-a-pot, you have to lift it up, take it to where ever you're dumping it, and do the unpleasant deed.
Then a quick rinse, and you're done.
With a permanant toilet, you have to tow the whole trailer to the dump station, get out the "sort of clean" drain hose, hook it up to your trailer, then slip it in the drain hole.
Then pull the knife valve to dump, then go inside to flush/rise the holding tank.
Then use a hose to rinse your drain hose, and put it away.
Meanwhile, your nose itches real bad...but it's okay to scratch it 'cause you were careful and didn't get anything on your hands...right?
If you use it a lot, and don't want to move the trailer just to dump, you can use a portable tank on wheels, but then you have to do everything twice. :thinking:
Another advantage to the portable is when you're driving home, if you really have to go :frightened:
and there aren't any restrooms in sight, you can just pull over and "relax".
If you're starting from scratch, installing a toilet isn't hard to do.
The trailer may need to be bigger than a standard tear, but that's okay because it has to suit you.
Rob
48Rob
Postby madjack » Sat Feb 04, 2006 5:58 pm
Jaffa, welcome to the board...48Rob is right on all counts...look at his photo's to see a full bath inna tear...albeit a rather large tear
madjack 8)
Postby cracker39 » Sat Feb 04, 2006 6:19 pm
If I make my TTT short enough that I have to bend over when I stand up, can I call it a tear???? Huh, can I? Can I?...nah...I guess I can't.
:cry:
But, what the heck... I like it!!! :thumbsup:
Dale
cracker39
Images: 233
Postby Boodro » Sat Feb 04, 2006 8:16 pm
hey Jaffa , how about this Loo????
Does this work for ya? :lol: :lol: :lol:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby Micro469 » Sat Feb 04, 2006 10:16 pm
Can't remember the website, but they had a toilet seat that attached to your trailer hitch..... O.K. so you can only use it when yer parked, but what the heck, at least its not near the galley! :lol:
John
Micro469
Images: 382
Postby Kevin A » Sat Feb 04, 2006 10:33 pm
Micro469 wrote:Can't remember the website, but they had a toilet seat that attached to your trailer hitch..... O.K. so you can only use it when yer parked, but what the heck, at least its not near the galley! :lol:
That would be "Uncle Booger's Bumper Dumper"
:lol: :lol: :lol:
http://www.bumperdumper.com/bumper2.htm
Kevin A
The other guy
Images: 289
Postby TomS » Sun Feb 05, 2006 2:29 pm
You can't put it on just any old hitch. It only fits a No. 2 reciever :lol:
Tom Swenson
[email protected]
TomS
6'6" porta potty
Postby Miriam C. » Fri Feb 17, 2006 9:49 pm
All jokes aside, If you fit in your teardrop you can do anything but stand up. Try "The Pet" and make like a budda with your news paper on the floor. If you are as old as some of the rest of us you will have assumed the correct position. :oops:
Second it the "Luggable Loo." It is a potty seat that fits on a 5 gal bucket. Again assume the correct reading position. :lol:
Postby madjack » Fri Feb 17, 2006 11:21 pm
...some of you who are interested inna unit a step up from a portapotti but not as complex as a full holding tank unit might want to look at these...Dale, one of these might work out well in your application
http://www.thetford.com/portable_cassette.cfm
madjack 8)
Postby cracker39 » Sat Feb 18, 2006 8:41 am
Jack, those are really nice, but look like a permanent installation. I really want the potti cabinet to sit my cooler on top of, so the potti must slide out for use, so I guess I'll stick with the porti potti. WM sells the model I plan to use. If I were to build something larger, I would consider these.
Dale
cracker39
Images: 233
