Half axles or full beam? Are their any down sides to using half axles or is it better to go with a full beam axle
Brwbier
madjack wrote:...with a full beam axle the axle tube acts as a crossmember eliminating one of 'em, with stub axles you haveta build bracing/crossmembers etc for them to mount on....however, they [half torsion axles] are less expensive and can give equally satisfying service...it is your decision after all
remarquian wrote:can report on how hard it was to get them aligned.
asianflava wrote:Not shure about the flex-ride but you can't use a Dexter as a floor support. It will tie the frame sides together but due to the peak in the axle it won't do a good job of supporting the floor.
Users browsing this forum: Google [Bot] and 20 guests
