StandUpGuy wrote:I am using a roll under the trailer tank.
fromeo wrote:StandUpGuy wrote:I am using a roll under the trailer tank.
Oh. Apparently I was posting while you were posting. A roll-around tank is going to be a different story then.
The only time I've seen a roll-around used in that configuration was with gray water on pop-ups. With those, the tanks are fed directly and rely on the vent built into the roll-around tank. I'm not sure that I'd be comfortable with that configuration on a toilet, that's a lot of potential odor under your trailer.
Running the closet flange into a horizontal tee to feed a vent pipe doesn't give me the warm and fuzzies either. I'd be concerned about waste backing up slightly into the vent tube causing some hard to rinse out stink.
Sorry I don't have a better answer for you.
- Frank
That was my plan to use such a tank. My new fear based on this thread is that the waste will get lodged in the tube and not reach the tank. With the perminent type tank the waste drops directly in the tank. I imagine a liquid soup is formed in the tank and thus can be flushed out more redily. I am only guessing as I do have experience with RV toilets and tanks. Any advice is appreciated.madjack wrote:...if you are using a tank similar to the one I linked to, you can flush directly into it with setup you have drawn.......
