Yard Eggs ...???
Yard Eggs ...???
Postby GPW » Sun Aug 21, 2011 8:08 am
Uh !! You ladies know how to tell if fresh yard eggs are good or not ... ??? Found a couple "bad eggs" in the last batch ... after they were hard boiled ... Ecccch !!! :o
Postby Big Dan » Sun Aug 21, 2011 12:05 pm
I think if you put them in water, the bad ones will float.
"Happiness is only real when shared" Alexander Supertramp
Big Dan
Postby GPW » Sun Aug 21, 2011 12:21 pm
Dan,. Thanks , I'll give that a try !!! :thumbsup:
Postby droid_ca » Sun Aug 21, 2011 1:45 pm
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby GPW » Sun Aug 21, 2011 6:08 pm
Droid , Thanks !!!! More to try ... 8)
Looks like it's all the Men that do the cooking around here ... :o
Postby wagondude » Tue Aug 23, 2011 8:12 am
Big Dan wrote:I think if you put them in water, the bad ones will float.
This^^^^^. If they stand on end but still touch the bottom of the measuring cup, thay are still safe to eat. If they lay flat they are fresh. If they come up off the bottom of the measuring cup at all, don't bother with them.
Bill
Bill
101137
wagondude
Images: 35
Postby GPW » Wed Aug 24, 2011 7:15 am
OK,float tested .... mine all laid flat on the bottom ... guess it's Breakfast time !!! :D Thanks !!!!
