Hi
I have a ford escape 6 cyl tow capacity is 3500 lb. I currently tow a pop up loaded it is about 2000lbs no brakes on the trailer and I have no problems at all.
I would like to convert a 6x10 or 6x12 V nose with enough head room so I can stand in it I am 6'2". The total weight loaded will probably be close to the same as I tow now, it will be a very simple conversion no plumbing or electrical.
I have never towed something that high before. What should I expect? Will the escape tow it easily? How much drag from the extra height vs the pop up will their be?
Thanks in advance for the replies
