This is what I’m Thinking about building. It’s going to be 12 feet X 6 feet (camper space). This will be a departure from the TSC frames that I have used in the past. A custom frame is in the works to accommodate the build specs. I may have to move the axel a bit to the rear when the trailer is built. The height will be determined by my garage door height – it may (or may not) have a dropped floor depending on the garage situation and when I receive the trailer. I’m not too concerned about the weight – since the trailer will have 15” wheels and a 3500lb axel.
