StandUpGuy wrote:So what is so special about waste storage tanks? They are just plastic containers with a few do-dads on them. So how about using another container modified to be a waste tank. Frankly I do not have a few hundred bucks to drop on storage tanks. First to start how about a grey water tank made from a 5 gal. gasoline container? I have a couple extra ones in the garage.
bobhenry wrote:You could always take the solids out of the equasion........
http://www.rei.com/product/679029/reliance-luggable-loo
Then the liquids will work in your 2" bung holding tanks.
http://www.rei.com/product/823665/reliance-double-doodie-waste-bags-with-bio-gel
bobhenry wrote:I found 40 of these !
The guy wanted $5.00 each.
I bought 6 for me and 2 for a buddy. They had contained car wash soap.
They have a 3/4" and a 2" NPT threaded bung just like their 55 gallon cousins.
I figured 1 for pottable water, 1 for rainwater harvest ,and one for greywater storage.
Draw from the 2" with a tee installed for a cleanout drain and utilize the 3/4" for the vent stacks
M C Toyer wrote:OK, makes sense.
You had said something about watering the bushes if you used a separete pee tank. In the Texas State Parks just dumping gray water is prohibited including washing hands, feet or dishes at the water tap.
I've seen a set-up in a van with a pee tank that had a trap which was filled with small amount of water after use to rinse and prevent odors.
I got both the square freshwater tanks with spigot and the thin upright tanks with spout at Walmart.
M C
