bobhenry wrote:You have turned on a little light in my brain I can get two 18 foot runs of 4" pvc in the plywood trusses on the caboose with little if any structural weakening of the roof system. Thats 24 gallon of water. 24 gallon that is stealthfully placed and will not be subjected to freezing temps with the caboose warmed for the inhabitants.
Damn it ! There I go thinking again !
angib wrote:You would want to include a dump valve to empty out the tank easily. Towing a trailer with a water tank in its roof does not sound like a good idea for its centre of gravity.
droid_ca wrote: I'd only fill it when I got to my destination so while traveling it would be mostly empty.
eamarquardt wrote:I think a better alternative would be to make your own fiberglass tank and put it under your floor between frame members. Wouldn't be that hard to line and top a wooden box with fiberglass. Custom shape and low for your center of gravity.
Cheers,
Gus
droid_ca wrote:eamarquardt wrote:I think a better alternative would be to make your own fiberglass tank and put it under your floor between frame members. Wouldn't be that hard to line and top a wooden box with fiberglass. Custom shape and low for your center of gravity.
Cheers,
Gus
I just don't have the floor space with 3 dogs myself and whomever I decide to take with me that's why I was thinking of gravity fed and up high
If there isn't water, the blue water jugs are fine.
capy235 wrote:Is PVC safe for drinking? Or are we talking about other uses?
droid_ca wrote:capy235 wrote:Is PVC safe for drinking? Or are we talking about other uses?
That was a question I wanted to know as well
in regards to the blue jugs I'm thinking I might need more water then what they hold but I have considered getting a few of them as well
Wobbly Wheels wrote:droid, when you to buy the pipe, it'll be marked 'potable' - most of the white stuff is, except for central vac tubing. When it's light tomorrow, I'll get you a photo of the markings: I've got a bunch for underbody conduits.
I've also got about 12' of 4" socked away for my own water tank (though it'll be underslung rather than a gravity tank...
