Presented for your consideration, comments or amusement.
I have a Harbor Freight [HF] flat trailer #94564 for hauling small equipment, mulch, dirt in & out of my back yard. Trailer is rated as 2050 pounds total when maximally loaded. I've never used it with than a a few hundred pounds on its platform, so far to deliver a boxed hot water heater, gas dryer & dishwashing machine to my front porch.
I think this might also apply to some owners of teardrops.
Towing my trailer is easy in all respects but one.
I've practiced backing this thing up for hours, and am no better at aiming this thing properly in reverse than when I started. I've given up on learning this.
I think part of my problem is the short length between the axle and the hitch. I have to be careful when turning sharply so that the trailer doesn't hit the back bumper.
I'm sure I would be able to back the trailer up if I could attach it to a front mounted trailer ball on my F150.
I am replacing the radiator support sheet metal on my F150 (the bottom has completely rusted out after only 11 years) and so have removed the bumper, grille, grille support and all the plastic attachments in front.
Looking at the front ends of the box beams (4" wide by about 5" deep) of the frame, I could easily bolt on a HF bumper receiver like this:
3500 Lb. Step Bumper Receiver
to either of the protruding ends of the box beams, using either U-bolts or through bolts to another plate on top of the beams.
I already have the receiver tubes, etc. needed to attach to the trailer.
I know this would be off-center. I don't think this matters for my intended purpose -- backing the loaded trailer at a maximum speed of 2 mph.
I know I could buy a regular frame mounted custom front trailer hitch for around $200 . I don't want to invest that kind of money for something used so infrequently, plus I don't know how much longer this particular F150 will last.
Is my idea practical? Safe?
