Shadow Catcher wrote:Are you looking to replace just the power unit or the housing etc. The prices I am seeing on ebay are higher than for Best Converter.
One of the listings appears to be only the housing because the wires are not hanging out the back?
GuitarPhotog wrote:I don't think the PD converters have pigtail leads hanging out the back like the WFCO does. But at any rate, I have to replace the whole shebang, and possibly my expensive AGM battery also. I can't tell if the battery will hold a charge because the charge circuit in the converter seems dead
I'll check out the places mentioned.
<Chas>
Shadow Catcher wrote:Sharon, be sure and monitor that your WFCO is doing what it should! My understanding is that they do not all fail in the same way. Also reported is the ones that don't fail outright do not put out rated current.
