MILESTONES, UPDATES, & MAINTENANCE:
02/01/2010: Started preliminary design using AutoCAD
02/23/2010: Finalized the profile and plans
03/04/2010: Frame assembly begins!
03/11/2010: Sawdust hits the floor
04/02/2010: Major assembly begins - sides, spars, bulkhead
04/10/2010: Major assembly finished,including hatch
04/11/2010: And then there was paint!
04/12/2010: Scuttlebutt goes for a test drive (minus doors and roof)
04/16/2010: Screen roof installed
04/18/2010: Vinyl roof installed
04/22/2010: Doors installed
04/24/2010: Curtains from Mom!
05/09/2010: Tongue box/12VDC electric finished
05/13/2010: DEPART on MAIDEN VOYAGE to TEARSTOCK!!
05/24/2010: Installed gas struts for galley hatch
05/28/2010: Install "bread shelf"
10/12/2010: Removable insulated ceiling panels finished
10/26/2010: Made removable oak trim ring clamp to seal the vinyl top around the fan
11/21/2010: Wired 110VAC outlets - 2 interior, 1 galley
12/25/2010: Got a Spa Sensations 4" memory foam mattress
03/22/2011: Added a divider and shelf in the lower galley
04/03/2011: Cleaned and repacked the wheel bearings
04/12/2011: Built underfloor storage
06/06/2011: Replace screen roof
06/16/2011: Modified fan trim ring/rain cover
08/01/2011: New curtains and hatch graphics
08/13/2011: Modified tongue with an extension
10/18/2011: SOLD to make room to build The X-II
ORIGINAL THREAD....
February 3, 2010
First with the basics... (for anyone who didn't read my noob thread)
The Urabus Scuttlebutt, based loosely on horrible plans from ebay, will be constructed using 3/4" plywood for the floor & sides. I was considering doing insulated sidewalls to save weight, but it would have over-complicated my first build. Also, with it being a convertible, the insulation really wouldn't have done much.
As for electric, I don't really do many campground trips, so I'll be sticking with basic DC for now... a tow-n-charge system with a deep cycle battery. I'm thinking 2 interior lights, one galley light, and a couple 12V power/5V usb sockets. All auxiliary lights are to be low power LED's.
On to the initial shopping list...
Trailer hitch & Harness for the Suby
4x8 1720lb Trailer
Fan-tastic Vent 4000R w/ low profile
D-shape weatherstripping (40 feet)
Black Beauty Asphalt Fence Post Paint for underfloor protection
CPES to seal the plywood
S.S. Piano Hinges
Power Tender Plus 12 Volt 5 Amp Battery Charger
(2) 'factory-style doors'
LED Lighting with Remote Control
3/4" Oak Plywood for sides
Helmsman Spar Urethane Satin for interior
Rustoleum Oil Based Enamel for exterior
Kilz Premium Indoor/Outdoor Primer
Snaps/Snap Screw Studs
Marine Vinyl removable top
Insect mesh roof
The design:
There are a few hurdles that I will have to clear once construction begins. Fortunately, Kerry (aka ToyPusher) lives a mere 10 minutes from me! Also, we have a member on here that has already worked on this type of teardrop - thank you Barb (aka b.bodemer) for sending me pics of the one that you helped complete!
