GPW":cfvyltwn said:No license plate ? ... or did we miss that … Looks great ...![]()
License plate will be on the bumper once installed. Thanks.
KCStudly":cfvyltwn said:Nice work as always.
For a little finishing detail that will extend the life of your wire cables, consider adding wire rope thimbles. They help maintain a minimum radius and keep the cable rope from kinking at the bend point in the eyelet loop.
For light duty applications such as yours, I sometimes prefer the crimp style sleeve instead of the cable clamps. The small ones for 1/16 dia wire can be crimped with a std set of wire crimpers intended for non-insulated terminals (the kind with a dimpling die on one side). Trim the tag end with a small cut off wheel in the Dremel and sheath with electrical shrink wrap.
Thanks KC, I looked at those, but was not sure if this was even going to work yet or not. Might redo it this way. Probably would look better for sure.
Redneck Packrat":cfvyltwn said:Looking really sharp!![]()
I bought a box of those screws a week or so ago. Always like the integral "washer" on the heads, figured I'd use 'em for *something* when I get to the detail work on mine. Had the 4.79 (?) at the moment, figured it wouldn't go to waste![]()
Thanks. I use those screws for a lot of applications. I have them in 3 different lengths.
