1995 18' HiLo Camper Trailer $1,000
Cliffmeister2000
Senior Member
Joined
Jul 26, 2007
Posts
3,622
The good:
Very clean inside and out.
Dometic 3 way refrigerator works great all 3 ways (120VAC, 12VDC, Propane)
Working rooftop A/C
Working stove, sink, water pump.
Working toilet and shower.
Sleeps 6 (Dinette bed, sofa bed, and bunk bed)
Relatively new, good tires.
Brand new deep cycle battery
Nice awning (awning cover needs replaced)
2 propane tanks
Comes with weight distribution trailer hitch
Tows very nicely!
The bad:
At least one (probably 2) walls need rebuilding in the top portion.
Hydraulics has small leak, so top doesn't go all the way up (we have had this for 2 years, this is a new development). Since my accident last year, I find it extremely difficult to get under this or anything else to fix or even add hydraulic fluid.
Top flexes enough when lowered that the door doesn't stay shut. This has been an inconvenience only, as I hold the door closed with a bungee when traveling, and the problem goes away when the top is up.
It is my belief that this unit is worthy of the time and materials to repair if you do it yourself. However, our HOA gives me grief if I even have the trailer here overnight, much less the time it would take to rebuild it, and it doesn't fit in my crowded garage.
So, buy it to rebuild it, or buy it for the appliances. I have priced it fairly either way.
This will be exclusive here until I get back from my camping trip on or about July 12th. Then it will go on both Craigslist and eBay.
Thanks for looking!
Great price, these are nice trailers. My mother had a similar looking/year. I hope someone buys to repair it not strip it.
In reverse order,
Tags are current through August of this year.
It is an 18'. Factory Weight 1900 lbs, Axle Weight 1710 lbs, hitch weight 190 lbs, G.A.W.R 2200/2200, G.V.W.R. 3000, Max Cargo 1100 lbs, tire size ST175/80R13
As far as model, all I know is: TowLite HiLo 18'
Cliffmeister2000":2944t2em said:
The good:
Working rooftop A/C
2 propane tanks
Tows very nicely!
The bad:
Thanks for looking!
Where is it located?
Looking at the paperwork, this thing has:
MagnaTek 900 Series Converter / Battery Charger (from Kokomo, Indiana
Thetford Aqua-Magic Fresh Water Flush Permanent Toilet (that I have never used)
H&H Engineering Electric Tongue Jack
H&H Engineering Auto Drain 12 volt (that I have never used)
Winegard RV Antenna (that I have never used)
Easy Lift Weight Distributing hitch
Atwood 6 gallon hot water heater (that I have never used)
Atwood Hydro Flame Furnace (that I have never used)
Patton Heater Plus fan (that I have never used)
Marshall 290 Series 2 stage L.P.G. Regulator
2 propane tanks
Dometic Refrigerator Model RM2202 (Propane, 12v, 120v, all works)
12v lights
Duo Therm 600 Series Penguin Roof Top Air Conditioner (used once, works great)
I have all these manuals as well as the TowLite manual.
Plus a 3 burner stove that works, but I don't have the manual.
