2022 Bushwacker
Chris_50
New Member
RV LIFE Pro
Joined
Jun 30, 2025
Posts
1
EXTENDED WARRANTY THROUGH 2029, bumper to bumper includes 24/7 towing and assistance. Lots of extras like wheel chocks, awning, RV Surge Protector, Wheel torque wrench and more. Title in hand. Also includes a winch mounted on front of trailer to pull into your garage space. And dual 6" trailer caster wheels.
This Teardrop camper will fit in your standard sized garage and has been stored in my heated garage since day one. Used for a three short trips as we decided to go class B. This trailer is in perfect condition, maintained, winterized and ready for your adventures. You can pull this with any car that can support a hitch, dry towing weight is only 1300 pounds. Heat, AC air conditioning, 24 gal water tank, stove, sink, cooler, water hose and pump, stereo with speakers in and out, interior and exterior lights. You can charge your phone and run small appliances. Heavy duty Marine battery, propane tank or direct propane hook up is available. Off road ready, 15" clearance, electric brakes, roof rack, rear support jacks, double entry/exit doors and much more. Local Chicago sale.
$10,499
Specifications
Length 13 ft 2 in
Ext Width 6 ft 9 in Ext Height 6 ft 10 in
Hitch Weight 120 lbs GVWR 2200 lbs
Dry Weight 1300 lbs Cargo Capacity 817 lbs
Fresh Water Capacity 24 gals Furnace BTU 12000 btu
Available Beds Two Twin Refrigerator Type K2 Summit Series Cooler
Cooktop Burners 2 Axle Weight 2200 lbs
AC BTU 5000 btu Axle Count 1
Number of LP Tanks 1
Electrical Service 30 amp
Braxton Creek Bushwhacker teardrop trailer 10HD highlights:
• Two Mattresses
• Overhead Cabinets
• Vortex Roof Vent
• Exterior Kitchenette
You and your loved one will have a great adventure with this teardrop trailer! Start your mornings off feeling recharged and ready to go after sleeping on the 4 inch deluxe comfort quilted bed mattresses. The Vortex roof vent helps to circulate fresh air in and out of the unit, and the 5,000 BTU wall-mounted A/C has a simple interface to cool it off quicker. There are LED lights and multiple 110V, 12V, and USB outlets conveniently located throughout. The exterior kitchenette comes with a two burner cooktop with cover, an integrated sink with a 24 gallon fresh water tank, and a Shurflo 12V water pump, plus a 30 quart K2 Summit Series cooler!
You can forge your own path with any one of these Braxton Creek Bushwhacker teardrop trailers! The roof-mounted, multipurpose gear rack is secure enough to bring your kayaks or bikes along with you. When the terrain is hilly or rocky, the dual rear, heavy-duty extendable stabilizing jacks complete with foot pads will come in handy. A torsion-flex 2,200 lb. independent suspension axle with electric brakes and maxi-clearance design, and the Norco stamped, heavy-gauge steel, powder-coated mainframe with EZ-extend hitch jack will hold up through every adventure. They also have oversized all-terrain radial tires with Apex gun-metal, rally-sport wheels and an under-mount hidden spare tire with an EZ-crank access system.
Features
Standard Features (2022)
Interior
• Under Bed Hidden, Padded Storage Boxes
• 4-Inch, Deluxe Comfort, Quilted Bed Mattresses
• Multiple 110V, 12V & USB Outlets, Conveniently Located Throughout
• 5,000-BTU Wall-Mounted A/C
• Bluetooth Compatible Stereo w/Interior Speakers
• Conveniently Located LED Lights Located Throughout
• Oversized Storage Cabinets
• Prepped for TV w/Cable Plug & Multi-Directional TV Antenna
• 12V, 3-Speed Vortex Roof Vent
• 30qt. K2 Summit Series Cooler
• 24 gal. fresh water tank
• 12,000 btu furnace, with wall mounted thermostat
Exterior
• Torsion-Flex 2,200-lb. Independent Suspension Axle w/Electric Brakes & Maxi-Clearance Design
• Oversized All-Terrain Radial Tires w/Apex Gun-Metal, Rally-Sport Wheels
• Heavy-Gauge, Powder-Coated Wheel Fenders
• Oversized, Lockable Entry Doors w/Built-In Slider Windows
• Welded, Aluminum Framed, Main Coach-Body Construction
• Durable Filon Fiberglass Exterior Skin
• Dual Rear, Heavy-Duty Extendable BAL Stabilizing Jacks w/Foot Pads
• Norco Stamped, Heavy-Gauge Steel, Powder-Coated Mainframe w/EZ-Extend Hitch Jack
• Heavy duty roof rack
• 30-AMP Converter w/30’ Detachable, Easy-Store Power Cord
• LED Exterior Lighting Package
• 2-Burner cook top with cover. Integrated sink with 24 gallon fresh water tank, and Shurflo 12V water pump.
• Heavy-Gauge, Powder-Coated Dual Battery, LP Tank & Generator Mounting Platform
• Under-Mount, Hidden Spare Tire w/EZ-Crank Access System
• Easy-plug Solar Prep Package
New posts
