2ND BUILD, WAS HERE A LON TIME AGO
Jeeper92
Senior Member
Joined
May 17, 2007
Posts
533
I secured a welder to weld me a 5x8 chasis and mount the leaf springs , build fenders, and tongue box. Bad thing is he have it done until February. As I think about it more its prolly a great situation. I have 5 months to secure all the things I need to build. Im going to build a non traditional teardrop in that its not round. Im looking to save as much weight as possible. What are you all doing to keep your weight down? Where are you scoring used parts? I just started looking on facebook market place and picked up 2 20x30 rv windows for 50 bucks. So im off to a good start. Any other places to check out?
My main approach to saving weight is to not install anything I probably won't use. So, there is no air conditioner, there is no sink, no plumbed in gas and no plug-in mains power.
I mounted a common aluminium framed glass solar panel - weighs a ton. You can get flexible panels that weigh a LOT less, with the added bonus that they flush mount really well, which improves the aerodynamics.
My sidewalls and floor are single layer of ply. I think it would probably work out heavier to make them skin-on-frame. Of course, I'm not camping in snow here in Australia.
I think it takes more framing to make a square drop. The curves on a rounded one make an important contribution to the rigidity of the whole thing.
Make every thing you can a structural element, rather than build framing.
I have wheels, tyres, springs and axle that are big enough for the job, no more.
How much do your windows weigh? My doors weigh a lot more than the pieces of plywood I cut out to fit them.
The little things add up. For example, if you use hardwood marine ply it will be heavier than if you used the same size pine-based plywood.
The trick is to only use it where you really need the better water resistance.
