kipa
Senior Member
Made a new lower insert for the tongue and replaced the top-wind jack with the front-winding one. Pretty easy swap for $50 and I think the space it frees up will be worth it.
As a woodworker, I am thinking I will just build the platform out of cedar and fully treat each board with blended tung oil before assembly.
It won't get much sun or extended moisture exposure really, so I don't see any need to worry about a more durable finish, so it's a strong, light, and relatively inexpensive option that should be easy to rebuild later if needed. I may just do the sides with smooth fence pickets as well, but probably not the top cover. Kinda depends on how it starts to turn out I guess. Cheap materials, easy to work with, yadda yadda . .
Dimensions are 34" front to rear and 60" at the widest point.
