6X12 SS&S
Iconfabul8
Senior Member
Joined
Apr 30, 2016
Posts
625
Welcome to my 6X12 SS&S (S**t Shower & Sleep) CTC!! This will be my (very small) Hotel room on wheels.
I just picked her up from the Pace factory in Springville, UT today. I've been waiting a long time for for this custom order.
  • 6" extra height
    RV door w/step
    Move door as far back as possible
    45 deg down start Torflex axle w/brakes
    White vinyl ceiling
Just got hooked up in the factory parking lot.
Nightshot. Just got home.
Table of Contents
Page 1: You are here so look around! First pics, Trailer description, Panel removal and begin insulating.
Page 2: Air conditioner install, Window headers and sills welded in. Talk about lighting.
Page 3: Insulation, Replace wall panels, ,More holes in trailer (Power and water inlets mounted,) Porchlight, and Factory screw up fixed.
Page 4: Ceiling up, Cargo and bad guy light mounted, Floor plan divulged, Shower stall moved inside and mounded, First wall!
Page 5: Bathroom floor, Ceiling lights.
Page 6: Bathroom wall, First pieces of trim, Bathroom fan, and Black tank fix.
Page 7: More holes ("The Dog Dish",) Install water heater, A little paint in the bathroom, Mount the waste valves.
Page 8: Mount gray water tank, Plumb gray and blackwater tanks, Build the gray tank inlet T confabulation, Start the shower sump install.
Page 9: Finish shower sump, Build propane tank mount and run gas pipe, Install shower valve and fresh water tank, Plumbed gray tank inlet. 1st WH experiance
Page 10: Build and mount rear bumper/stinky slinky holder.
Page 11: Bought a bed (futon mattress) and Batteries. Battery charging discussion ensued.
Page 12: Built the bed/couch frame, Fabricated the Battery box, Took a little trip to Idaho/Wyo to watch the sun disappear.
Page 13: Begin the indoor water plumbing (Manifold.)
Page 14: Finish water plumbing, Build DC buss board, More molding.
Page 15: Wood block molding, Finished side walls (Cedar t&g, tin, molding, plugs and switches,) Gas line pics, Inverter wired and mounded.
Page 16: Television and glass table installed.
Page 17: Water heater vent pipe and glass table revisited. Begin building overhead storage/luggage rack.
Page 18: 3 final lights mounted (Copper conduit), Begin discussion on cutting holes in trailer.
Page 19: More holes discussed, Toilet fix, Bathroom fisheye pics.
Page 20: Paper towel rack and TP holder, Overhead compartment door, First window installed.
Page 21: Pine Valley trip, Leveling jacks installed.
Page 22: WiFi Booster, Sink
Well, that's pretty nifty having the side door back where you have it. That would give you some interesting design options inside. I like it!
Dave
Very nice! I'll be following your build.
Dave
That will give you a lot of usable space!
Very Nice! I am looking forward to following your progress> :thumbsup:
Nothing is ever easy is it? I started stripping the inside to get ready for insulation, and all the various and sundry holes I need to punch in this thing. Well half the boards have screws in them from outside the trailer. But the worst was the 120 or so staples every couple inches holding the vinyl clad boards to the ceiling. If you look close at the first picture you can see them all along the edges. The second picture and video shows my solution. I cut off a bolt, drilled a hole through it, sharpened it and cut a few teeth in it. The pic shows it after I had used it a while and is a bit dull. I had to sharpen it a few times. If I were doing it again I would make it out of a #8 bolt and harden it. Those staples are rough on the edge when you hit one. I suppose I may have been able to get under the staple with a tool of some sort and pull the staples through the board, I just figured this would cause less damage. Trim should cover it all in the end.
[youtube]frA6qtHhO60[/youtube]
Is there insulation under the ceiling panels or do you have to remove them to install insulation?
Removing to insulate. I originally ordered factory insulation because I didn't want to go through this, but I learned that they use bubble wrap, so I cancelled.
I really like the idea of moving the door back a bit. It really opens up the options for you. Looking forward to seeing the floor plan and progress you make.
I see. Sorry you had to go through the staple removal to get the panels off. I am in the process of putting up ceiling panel myself. I am using screws. Best of luck with your build. I like your trailer.. I can see the back end of your truck in the photo. It looks like mine from the rear.. I have a White F150 4x4 tow vehicle also, :) :thumbsup: :thumbsup:
I am sure this isn't too exciting for everyone else. It is after all just another trailer with all the wood off and some xps insulation in the ceiling. But I am as giddy as a schoolgirl! :p :dancing
What have you all been paying for 1" xps?
Since the ceiling already had the wood on the struts for mounting the vinyl panels, I am going to put some 1/2" eps in between the boards. It should help a little.
I can guarantee you that I will be using screws when it goes back up. Luckily they used screws in the field. Yep, I have enjoyed my f150 so far. It has the Ecoboost and "knock on wood" it has been amazing so far. It's a 2011 and I have about 150K on it.
Yes we all posted the same insulation pics, but I like to see them anyway. I think we all relive our build vicariously by watching others complete theirs, and we're happy to see you making the same progress we remember from our own builds.
That is great on your F150! I have a 2011 also but only 46,000 miles so far. I have the 302 V8 in mine, but love it! Nice job on the insulation!
Having that door moved back was an epiphany. That gives a lot more options for interior design. Way to use your noodle! :applause:
McDave
Ok, it's been a few days. I have not wanted to post pictures until this particular project is finished. However! Here are a couple teaser pics. Any guesses as to what I am doing?
m.colley":27ph8t1r said:
looks like a frame to mount a window ac possibly.
Martin
Yep.. Window.AC Mount. I need to build.one myself.in the next few weeks.
Is that being built in a way to have the AC in a cabinet and not extend out the side, or will it extend outside. I am building one to be internal with a intake in the ceiling and vent out the wall. I have never done this before,.so for me, it is learning by doing. Anxious to see how you do it. Way to innovate! :applause: :applause:
With all the wood off the ramp and a big chunk of wood removed with the help of a router I began to cut a big hole in my ramp. Make sure your router bit is in tight and that you have the proper depth or you will end up with unwanted holes in the skin. I then cut a section of square tube. I was kinda spooked of going through the skin. Oh I should point out that my skin is glued on, so no taking the screws out and putting something between the aluminum and tube. With a grinder and a thin cutoff wheel I cut 1" away from the hole I wanted to cut to allow for a piece of square tube. I had to be careful not to go through the aluminum so I didn't cut all the way through. I came back about 3/8" and did the same cut. Then I cleaned out all the metal between the cuts, so now I have a wide slot with metal still on the bottom. I then went back over an inch where it wouldn't matter if I went through the aluminum and cut all the way through the square tube. I then cut on the original cut a little more but still not going through. Then I used some mig wire to cut the glue from the full cut to the original cut. This allowed me to bend the small piece until it broke and Voila (Wah Lah!) Didn't even have to get the grinder near the skin.
With the new tubes in place I was ready to weld them in. The dumbbells on lthe ramp keep it from slamming shut. Wont stay open without the wood.
Cutting the tube out.
The Roto Zip made short work out of cutting the hole.
Ramp is insulated and ready for the decking. The clamps are holding some flat pieces on the skin keeping it flat while some silicone dries on the new tubes.
Router worked great! I now have a hole in my ramp. Who would do such a thing? :roll: :thinking:
Filled the hole with this thing.
Built this.
View from the other side.
And put it all together. :)
View from the Right
View from the left
And Look! It opens!!
Ramp down
The reason I went this route was, all I will be hauling in and out can be done with a hand truck.
New posts
