6X12 SS&S
Looks great guys. I’m jealous of the full bathrooms. I’m just gonna have a portapotty sitting in the shower stall.
Iconfabul8
Your trailer is amazing! Your build and Flboys were the first ones read all the way thru and you guys do awesome work. Got me itchin like made to get in gear building my trailer!
James
featherliteCT1":2wzy7tsa said:
Beautiful!
JRAnt74":2wzy7tsa said:
Iconfabul8
Your trailer is amazing! Your build and Flboys were the first ones read all the way thru and you guys do awesome work. Got me itchin like mad to get in gear building my trailer!
James
Thanks James, Joel and featherlite . Welcome to the forum James. Sounds like you already have a trailer, what do you have?
flboy":jqntzwvq said:
I never thought about using a fisheye lense! Your BR looks great. Nice roomy shower!
Thanks Don, yes I do love my roomy shower. And your Bathroom is so homey, It makes me want to brush my teeth or something! :D :thumbsup: :applause: Love the fisheye shots too :thumbsup:
Welcome to the forum James. Sounds like you already have a trailer, what do you have?[/quote]
My trailer started off as a 6x10 or so pop up camper that got damaged in a storm, I plan on converting it to a flat bed utility trailer. I know it backwards from what you folks do here, but its what will be most useful to me. I just hope I could still hopefully get in on some of the fabrication discussions here, since there isn't a site dedicated to what I'm doing.
James
Soldered me up some camp gadgets!
Screwed them to the wall.
Presto! a paper towel rack.
Probably not hard to figure this one out.
Equipment (TP) installed.
Hung a bath towel rack while I was at it.
Iconfabul8, Howdy;
Mr. Steampunk strikes again!!! :thumbsup: , :thumbsup: !
Truly enjoy seeing your "tweeks and adjustments".
hank
Hey Icon,
Do you clear coat the copper conduit and accessories or allow to age and patina naturally? Bright, clean, new penny copper is beautiful, especially in contrast with the color of your wainscoting, but aged copper has it's own appeal. The verdigris from chlorides is similar to your wall color.
McDave
Thanks Guys!
McDave":2brrfuoe said:
Hey Icon,
McDave
I have been spraying it with some of this stuff:
I hope it holds up OK. It says it's good on metal. I guess we will see.
I got my half door put on my overhead compartment today.
Been looking for just the right hinge and found just what I wanted, hidden in a bin at Home Depot. :P
The built in closer works fairly well to keep the door closed, but I will probably put a magnet of some sort on it as well.
You make nice stuff Iconfabul8! Thanks for sharing! :thumbsup: :thumbsup:
Are you going to cut in that window soon?
Lookie! Lookie! I finally put a window in! :P :sneakers: :wakka wakka: :moom walk: :running man: :beautiful: :woohoo: :dancing:
I do things a little bass ackwards I suppose. Windows are one of the first thing most of you do, but then again I still have no flooring either.
Rewarded myself by buying a itty bitty microwave.
Looks fantastic! Really makes me wanna buy an enclosed cargo trailer, just so I can give it a go!
Steve, Are your 110 outlets surface mounted and what you see is actual depth? If so I would like to know more about the system with the wire chases, looks great.
Also regarding your 3-gang 12v switch panel...is it recessed in your wall cavity?
Do it!!!
Yes the outlets are surface mount. They are Legrand Wiremold stuff. I picked them up at Home Depot: Outlet Box. Scroll down on this page and it gives all the sku for the series 700 parts.
The switches are mounted in the wood blocks, no ressessing. I probably should have a little, It was a tight fit and I had to do a little shielding to keep wires separated. This post on page 15 gives a good view of how I did it. The blocks are about 13/16" ish deep.
:applause: Nice job on the window. I was starting wonder if we were gonna have to send Don over there. He loves cutting holes in new trailers.
I put in a microwave as well. Didn't think I would use it much but I actually have. Are you familiar with Chicharrones? Or microwave Pork Rinds in gringo. Pretty awesome. If you can find the Hot & Spicey even better, or just hit em' with the chili powder while still hot. They are low carb so they gotta be good for ya.
image.php
McDave
Man, I really dig how that copper looks for running the electrical. I was going to go surface mount with EMT for my wiring, but this may change my mind.
Is there any downside, aside from cost, going this route versus EMT? Any safety issues?
I can't think of any safety issues that wouldn't be present with emt. But l did only run 12 volts in it. My biggest concern is if the clear coat will keep it pretty. Painted emt looks pretty good. Not quite like the real thing, but an option. Also I used the super thin wall stuff, it is less money! Can't wait to see what you do.
Iconfabul8":gxrntvdc said:
Do it!!!
I probably will after i finish my utility trailer, and make some money with it. Need to replace the funds first. My best friend is interested in doing a joint venture on a CTC.
James
