Hi All,
Thought I would start my build thread to share some of what I have in mind that might help others as well with a list of my resources. 6x14 with 72 inch extended tongue and electric brakes. Name, Rolling Thunder or Roaring Thunder. ON a budget, we'll see what works and what doesn't .
I was sooo excited to build a teardrop wanted a cool woody but was afraid it would not turn out as well as I like. Plus for my needs it was just a little too small. Was close to buying a harbor freight trailer when they recalled the tires. So happy I did not and know this is the direction to go for our needs.. Trying to find something light, secure and will last, ended up deciding on a Cargo Trailer Conversion. I like the fact that they are built with 15 inch tires and can be pulled at fast speeds. I keep it just under 65 very comfortable pull.
6x14 was as large as I could pull with a six 2.7, 2700-3300lbs pull cap on our 2005 Hyundai Santa Fe TV . The weight comes in at 1600 lbs and has brakes. Love the brakes. Pulls great. Plan to try and keep the added weight to 550lbs. The BIG test will be going up and down the canyons here in CO.
Ordered and picked up the Trailer in Pearson GA. South Georgia Cargo is the factory. Sold by Plain Ol Trailers, Their site is makemytrailer.com . The prices are good and it was easy to plan out. I dealt with Barny and he gave his personal number and was great to work with. The trailer was made to order quickly so off I went from Colorado to Georgia and Back again. ( BTW I get no benefits on any of the links or resources just sharing.) Cost $3392 out the door not including tax and registration in Colorado.
“Google Maps NO highways or Tolls I LOVE YOU!” Took direct route on the way there and it was crazy going through KC, St Louis and Atlanta and this was on the weekend. Longer drive on the way back but I did not hit any traffic or major cities. THANK YOU GOOGLE!
Great road trip, trailer pulled fantastic. Trailer is solid and when you buy from any GA builder you really have to look them over well. I found some missing screws that they fixed right away.
It was not until I got to LA… lower Alabama that I realized they did not put the paid for window in the door. And that’s another story. Anywho, Barney got back to me right away and is sending a window and said they would pay for install. So they are doing the right thing. So I will still recommend them. ( have not received the window yet)
Here is a video below
[youtube]6nYynND06k[/youtube]
A very BIG THANK YOU to Iconfabul8 for helping me with the sketch for window placement.
So now the fun begins. Need to tax title and register this week. Not looking forward to the cost there.
Next, to keep weight down I am going to sand, stain and poly the plywood on the walls and floor.
After staining with Golden Oak.
Light Cabinets will be covering most of the walls so I may only skin in exposed places with barnwood paneling or leave as is.. Thinking about making cabinets with this as well hoping it is thick enough if not then the birch for cabinets and the paneling for accent. I guess I am going to have to take some cabinet making classes.
Hoping these will work below. Cool looking NEW products.
Home depot Authentic Pallet 32 sq. ft. MDF Paneling 20lbs a sheet 4x8. https://www.homedepot.com/p/Authentic-P ... /302944322 $18.95
Lowes - 48-in x 8-ft Smooth Weathered Barnboard MDF Wall Panel - 20lbs https://www.lowes.com/pd/48-in-x-8-ft-S ... 1000065005 $16.95
Lowes Revolution Ply 5mm Poplar Plywood, Application as 4 x 8 - $14.95 - https://www.lowes.com/pd/RevolutionPly- ... 8/50121135
Check out these cool cabinets made from foam another option.
[youtube]ucf2FVIdr1Q[/youtube]
[youtube]qiI0AnPPySg[/youtube]
[youtube]Zey86bX5L3E[/youtube]
The walls are insulated so next will be wiring everything 120 AC and 12V from the ceiling, insulating and skinning. Either white or birch on ceiling with built in led lights.
Electrical 30am box next to v nose driver side. DC and controller in v nose as well.
AC list
Panel Murray LC002GSU Load Center, 2 Space, 4 Circuit, 60A Main Lug, Indoor, Surface mount $13.97 https://www.amazon.com/gp/product/B000B ... 0DER&psc=1
Murray MP1515 Two 15-Amp Single Pole 120-Volt Circuit Breaker - $9.99 https://www.amazon.com/gp/product/B000B ... Y6KH&psc=1
Murray MP2020 Two 20-Amp Single Pole 120-Volt Circuit Breaker - $11.54 - https://www.amazon.com/gp/product/B000B ... 0DER&psc=1
GFCI Wall Outlet -SECKATECH 15 Amp 125 Volt Tamper-Resistant Receptacle with Indicator Light,2 Nylon Wallplates, Screws,White. $11.99 https://www.amazon.com/gp/product/B01KZ ... N6HL&psc=1
12 gauge wire and 10 gauge wire from Lowes or Home Depot.
RV Electrical Locking Adapter 15A Male to 30A Female Locking Plug Connector $19.99 https://www.amazon.com/gp/product/B01B8 ... 8EF1&psc=1
GoWISE Power RVP5001 RV Power Inlet - 30A w/ Twist Lock $10.00 https://www.amazon.com/gp/product/B01K0 ... 4FRY&psc=1
DC list and Solar
Blue Sea Systems ST Blade ATO/ATC Fuse Blocks $40.35 - https://www.amazon.com/gp/product/B001P ... 0DER&psc=1
30AMP Solar Panel Charge Controller PWM Battery Smart Regulator with USB Backlight Display 12v/24v (30A) $32.00 https://www.amazon.com/gp/product/B0737 ... S76R&psc=1
Switches - Yueton 12pcs Car Truck Rocker Round Toggle LED Switch On-Off Control, Blue, Green, Yellow, Red $6.99 https://www.amazon.com/gp/product/B011U ... SCVJ&psc=1
Lights for the ceiling - 12v-LEDlight Marine White Recessed LED Ceiling Lights - Easy to Install (screw free) Cabinet Counter Lamp Campervan Trailer 5th Wheel RV Truck Car Bus, 3w, Bright Natural White, Pack of 6 with Bonus $36.99 https://www.amazon.com/12v-LEDlight-Mar ... op?ie=UTF8
RV WALL MOUNT 12V-VPA SOCKET/5V4A OUPUT DUAL USB PORT CHARGING STATION, WHITE $17.95 https://www.amazon.com/dp/B00SVVQHKW/_e ... 1N98&psc=0
White Wall Mount 4 USB Charging Ports 12-16V DC Fits standard wall plates $17.95 https://www.amazon.com/dp/B00ZOIIQAO/_e ... 1N98&psc=0
Reading lights for bed - RV Reading Light LED Directional Spot Light for Boats RVs Interior Lighting Touch On/Off/Dim Switch Brushed Nickel 12 Volt Hard-wired $19.95 - https://www.amazon.com/dp/B071DGQNDR/_e ... 1N98&psc=0
For lighting around top inside border or walls for low key lighting. 5m Meter 16 ft Feet RGB 5050 SMD LED 300 LEDs Waterproof Flexible Light Strip w/ IR Remote 24 Key - https://www.amazon.com/dp/B00IA5M4G0/_e ... 1N98&psc=0
100 Watts 100W Solar Panel 12V - 18V Poly Off Grid Battery Charger for RV $100.00 https://www.amazon.com/gp/product/B01HH ... FX8U&psc=1
2 batteries in parallel - ML35-12 - 12V 35AH DC DEEP CYCLE SLA SOLAR ENERGY STORAGE BATTERY - Mighty Max Battery brand product Amazon $63.98 & FREE Shipping https://www.amazon.com/dp/B00K8E4LR6/re ... B008D5YG3G
Walmart same battery free shipping $66.95 https://www.walmart.com/ip/ML35-12-12V- ... /126655222
Zamp Solar RVROOFSIDE Sidewall Port - $12.73 https://www.amazon.com/gp/product/B00T3 ... 0DER&psc=1
Lumitronics LED RV Exterior Porch Light with On/Off Switch and Removable Lenses. Perfect Outside Replacement 12V Lighting for RVs, Motorhomes, Campers, 5th Wheels, Trailers.! $11.99 https://www.amazon.com/dp/B010PDSLH0/re ... rd_w=tq70n
Plan to insulate floor from underneath.
Flooring
One piece vinyl flooring inside to keep things light . TrafficMASTER Redwood Acacia 12 ft. Wide x Your Choice Length Residential Vinyl Sheet Covers 12.0 sq. ft. $10.24 /linear foot - https://www.homedepot.com/p/TrafficMAST ... /300866841 Throw rugs on top of that. Need to know if I should glue or just float?
FAN
Fan-Tastic Vent Roof Vent w/ 12V Fan - Manual Lift - 14-1/4" x 14-1/4" - $128.00 https://www.etrailer.com/RV-Vents-and-F ... 01200.html
Fan-Tastic Vent U1500BL Ultra Breeze Vent Cover - Black $50.82 https://www.amazon.com/gp/product/B007H ... UTF8&psc=1
Kitchen in the front V nose. Most of the time I am out late photographing the sunsets and such so the need to cook late inside bug free is always nice.
Was thinking a light metal backsplash like copper or even a flooring product. Like this vinyl tiles. https://www.homedepot.com/p/TrafficMAST ... /206443738
Another idea Union Corrugating 2.16-ft x 8-ft Corrugated Steel Roof Panel - Lowes https://www.lowes.com/pd/Union-Corrugat ... el/3317582
Stove
Would you do two or three burner?
Suburban Drop-In Cooktop 2 Burner Black - https://www.adventurerv.net/suburban-dr ... -2862.html or
Not sure which on to go with. 2 or 3 burner. Last thing to order.
Suburban Drop-In 3-Burner Black Cooktop Stove https://www.adventurerv.net/suburban-dr ... -2865.html
Refrigerator Hisense 3.3 Cf Compact Refrigerator 46 lbs - $99.00 This will be used as an Ice Chest refrigerator with two gallon frozen jugs ( last about three days) boon docking and plugged in at campgrounds. https://www.walmart.com/ip/Hisense-3-3- ... /811182219
Microwave -Mainstays 700W Output Microwave Oven 23 lbs - https://www.walmart.com/ip/Mainstays-70 ... tual_color
Sink - HOUZER Hospitality Lustrous Satin Stainless Steel Drop-in Residential Bar Sink $47.80 5lbs 15x15” 6”D https://www.lowes.com/pd/HOUZER-Hospita ... nk/3663820
Leaning towards this cool sofa / bed . 60lbs (between kitchen and bed drivers side) Not using the legs and building a storage box for it to sit on. $174.00 https://www.amazon.com/dp/B01LXDH29Y/_e ... 1N98&psc=0
To balance the weight thinking about placing batteries opposite passenger side with built in unit and folding up table under 30x30” window about 60lbs with cabnet
Bed in the back across side to side, storage underneath. About 12” from back galley. (only works for short people and we are ) I use this same bed in the back of my SUV and it is very comfortable. Cr Sleep 4-inch Folding Memory Foam Mattress Full Size, Ventilated Mesh Cover, 54 x 74 inches $104.79 . Used this when I picked up the trailer and worked ut great. - https://www.amazon.com/gp/product/B0713 ... UTF8&psc=1
Window Coverings - pull down blinds. Levolor Cream Room Darkening Cordless Vinyl Roller Shade (Common: 37-in; Actual: 36.5-in x 78-in) https://www.lowes.com/en_us/mylowes/pur ... =345200411 these can be cut to exact size at the Lowes store. $10.97 – $21.97 Price is right. Do not have the skills to make custom drapes so this is a great option.
Back Grill Galley with cooler, storage and small doorway in the back with awning. (hoping this will balance the front weight a little too)
Back Awnings
Timber Ridge Car Canopy Family Trailer Outdoor Tent for Beach Camping SUV 3-4 persons Sunshade $85.99
https://www.amazon.com/dp/B06X3V19P4/_e ... 1N98&psc=0
KingCamp COMPASS Awning Sun Shelter Auto Canopy Camper Trailer Tent Roof Top for Beach, SUV, MPV, Hatchback, Minivan, Sedan, Camping, Outdoor, Anti-uv Tents, Waterproof, Portable. $97.99 https://www.amazon.com/dp/B00Q4CQLY2/_e ... 1N98&psc=1
Outsunny Car Awning - Portable Folding Retractable Rooftop Sun Shade Shelter (Small) $99.99 https://www.amazon.com/gp/product/B071Q ... DQCJ73A2H4
Front Canopy - On our Pop Up we had a great cabana we loved so that was hard to find at a good price so this is what I came up with.
Canopy and room. For Door side of camper. 10x10 heavy duty canopy Hoping the height will work with the camper door. $129.00 https://www.amazon.com/dp/B01LAPSV04/_e ... 1N98&psc=1
Two Door Canopy Room - $99.00 https://www.amazon.com/dp/B00818JBUS/_e ... 1N98&psc=0
Flame King (KT20MNT) Dual RV Propane Cylinder Rack for front mount. $27.73 https://www.amazon.com/gp/product/B00IZ ... 0DER&psc=1
Last will be Added outside Exterior Graphics image gallery on the white siding and you know there will be some lightning bolts!!!
That's the plan man...
AC list
DC list and Solar
Flooring
FAN
Stove
Back Awnings
