The heater buddy needs to be on a quick disconnect or shut off valve unless I mount it and leave it hooked up. Not sure I want to do that. I have three weeks to get that done.
Got the sink finally done yesterday with switch and better tubing. Was having a problem with the tube curling up in the tank. So I put a pvc pipe insert and drilled a bunch of holes, it keeps the hose strait to the bottom now.
Thanks again for the link!
As the beat goes on....
I would install a regulator due to the fact that you have a cook top installed that is,
apparently, unregulated. That in turn will create a problem with the Mr. Buddy, as it
has it's own regulator which you will need to find an approved work around (Google
is your friend here). If you had a self regulated stove (Coleman type, no affiliation),
then you would be able to use the above linked items as is...
Regarding altitude, I live at or near 4600' have lived at 6500' no problems that amount
to a pile of beans. Now if you go up to Winter Park, then you might have some ...
hank
