7'*18' V-Nose Cargo Trailer Toy Hauler Conversion
flboy, Howdy;
I'd imagine that if you were to think it through you could find several duplicate
items that you could do that with. Problem only arrives when the need to turn
one into a guest lodging at home and need to go camping at same time. (MiL
visits come to mind). chucklin'
hank
hankaye":zjixkyh2 said:
flboy, Howdy;
hank
Hi Hank. No risk of a MIL coming anymore... but I can think of a SIL coming that just may prompt me to go camping for the duration. Lol [emoji6]
I have tried not to have too many items I share between trailers as it there always seems to be something left behind. I like just to throw in food, water, and clothes along with a few totes in my shed and take off.
All of those to replace with one LiFePo4. About 55aH of more capacity (225a useable vs. 280Ah) and about 185 lbs lighter... not to mention charges quicker and etc.. Nice change.
The Golf Car batteries are 59.4lb each vs. 52lbs for the 280aH LiFePo4.
Got that job done. Solar Controllers are reprogrammed for LiFePo4, now I have to figure out what do with the 55A PowerMax PM3-55 charger/converter. May need to switch it out with the converter in the 6x12 if I cannot make it work for LiFePo4 instead of the FLA Golf Car Batteries. [Edit--- was able to drill rivets in case, remove the cover and I found an output ajustment potentiometer. I was able to adjust the Boost Mode output down to 14.4V from 14.7V. That should work fine for the Lithium Battery. Whoo Hooo.. don't need to spend more $$]
I do need to neaten up the wiring in there now that it is vacant. Probably will put a basket to store tools in the empty space.
flboy":22evnjm0 said:
was able to drill rivets in case, remove the cover and I found an output ajustment potentiometer. I was able to adjust the Boost Mode output down to 14.4V from 14.7V. That should work fine for the Lithium Battery. Whoo Hooo.. don't need to spend more $$][/b]
Wow! :thumbsup:
While I had the 280aH LiFePo4 battery out today, I also installed an active balancer. You can see it on the front of the case with the wires running inside. The BMS just doesn't do it well and I was seeing some top end imbalance which I believe is due to the internal resistance of the warranty replacement cell being slightly different than the three original cells. The active balancer can pass up to 1.2A between cells to ensure a good balance. A better balance should increase the efficiency and life of the bank. The balancer has some indication LED's on the board when it is working, so I installed it on the outside (under a protective cover) so I can see them. It actually works well. It balanced the cells from 81mV total to 3mV in about 30 minutes. The little board was worth the $10. My 230aH bank in the 6x12 CTC stays reasonably balanced, but I will probably install one on it just because i bought two of them. :D
Got the old girl out of the back yard. Cleaning, inspecting, and loading for my month long trip out to Nebraska next week. Been almost a year since I used this trailer.
flboy, Howdy;
Draggin' the "Hanger Queen" out for it's annual dust & clean chucklin'
What route are ya thinkin' about taking? Lot's of different ways to get there from
where ya are. All kinds of different terrain to choose from. Had ta ask.
hank
Hi Hank. Good to hear from you. The hanger queen is ready to go.
I am only going as far as Nebraska. Going to head West on I-10 as far as Alabama then secondary highways to angle up. Will pass through Arkansas and Kansas and probably tough on Mississippi and Tennessee as I work my way up.
In any case.. not in a big hurry.
Hope you have a great summer.
Checking all the systems before I leave in a few days. Appears the LiFePo4 active balancer is working well. The battery bank was just finishing up a charge cycle after the solar panels got some sun this morning. I could see the balancer was active (red LEDs on) and balancing off a 70mV differential between cells. It will take the differential down to 3mV. Solar chargers seem to be tweaked just right with a 3.60V max per cell (14.4V total). No BMS limits being breached. :-)
flboy, Howdy;
Don, the retired truck driver is curious about the route you'll
use. Pass it along when you feel like it. Who knows, may be going
near some of the others.
hank
Taking the 18' this time.. Is your wife going with you?
Glad to see you'll be out running around..
I live for the adventure, and when I'm not able to do it..
I enjoy reading about those that do..
Have fun and be safe...
hankaye":23vw8641 said:
flboy, Howdy;
hank
I left home on the 4th early AM. Figured traffic would be light on the 4th since people are where they want to be by then. Went 195 to I10 to I75 to I24 to I57 to I64 to I70 to I29 into Nebraska, then state roads to final destination. Traffic was light as expected. Boondocked in truck stops (Loves and Pilot) for 2 nights. Made it in to Nebraska destination today late morning..Roughing it tonight on the 6th in the 7x18 CTC. Will be here for 3 weeks. Take care.
Hi. Hope all is well with you. I too enjoy adventures. Wife is not traveling with me on the road this time, but will fly in for a week while I am here with our son and grandkids. She cannot be away too long right now as she looks after her mom whose health is failing.
I did take the larger 7x18ft CTC this time since I will not be offroad on this trip. It is nice to have the extra space since this is my home for a month. My dog Lexus appreciates the floor space, believe me. Lol.
Hope you can get out there soon. Be sure to post up to share your adventures. Take care.
Anyone been kicked out of a Bucees? I was sleeping in the CTC and got the knock on the door about 1AM and told I could not not park overnight. New policy reportedly just put in place according to employee kicking me out. This was last week at the Bucees just North of Atlanta on I75. I hope this will not be corporate wide. I had to move on to a Love's Truck stop near Chattanooga.
bdosborn":1j9d20hz said:
I've never looked at thier website, but I have been doing it for a while now as I transport RVs from Indiana factories to Fl. dealer when asked. This is the first time I've been approached and asked to leave. No signs to that affect that I have seen and I see many others doing it as well. I suppose it is over for me now. Was nice while it lasted. :( :(
