Jwh92020
Senior Member
Latest project is a 7x12 "Standy" square drop. The guy I'm building it for found a 6x12 trailer with a 5000 lb axle, so I extended the deck to 7ft wide. The deck is 1/4" plywood on the road side primed with 2 coats of oil based primer and 2 coats of oil based exterior paint. The deck frame is 2x2 and is filled with 1.5" foam board and the floor is 1/2" plywood. Walls & roof are 2x2 framing, with the side walls glued (Loctite Power Grab) and screwed to the sides of the deck frame. The front & rear walls sit on the deck. Interior height will be 6'2" and interior width will be 7ft. The exterior "sheathing" is 1/8' luan glued and stapled to the framing and will be covered with house wrap. The exterior walls will be cedar shiplap that will be oiled on both sides with Western Red Cedar Penofin Oil, and the roof will be 26 gauge roofing metal - flat sheets, no ribs. It should look like my profile pic. More to come...
