Paintsalot
Senior Member
- Joined
- Nov 14, 2021
- Posts
- 259
Thanks Sharon for input. I looked again at bed slats using cedar. They would actually be lighter than the plywood- but too bendy. So I’m sticking with plywood plus pine 1x2 frame.Either way, you're going to have an exposed edge, whether it's on the top of the lid or on the sides. If you treat the wood with a finish, I doubt it will matter much. The sides of the bench don't (and shouldn't) have to be 1/2" plywood. Your cabinet and bench sides should be 1/4" plywood with lightweight 1x2 framework. The top is 1/2" thick because you will be sitting and laying on it, but the sides don't have to be that thick. The strength is the sum of its parts.
I plan to use 1/4” Baltic plywood for top of bed/bench. It will span 15” max- I don’t anticipate a lot of flexure. I will have to add blocking where there are hinges because the quarter inch plywood won’t hold the screws very well. I’ll leave the sides of benches open. If I need to add sides I can do it later. I know things might fall out, but I’ll have a bottom rail- see sketch above - the sides could even be just stapled fabric. But I like the convenience of it being open where I can just throw some shoes under there. I probably will keep the cooler in my car. I plan to bring some kind of potty bucket that will store below bench.
Good point about hinge point -I’ll make sure it’s out enough not to bind. If I bring it too far it adds more structure. I’m trying to go as minimal in weight as I can.
I won’t normally carry any art gear in camper because I work in oils- the smell of solvents is not great for sleeping quarters. All art gear in car.
I’ll probably have a kitchen box of some kind - I don’t do a lot of cooking. I plan to have an pole awning on one side- with a side table for cooking. I can probably use one of bed supports as the table. Or have a fold down kitchen box.
I’m prepping for an art show- so camper will have to wait some this week.
Cheers.
