Paintsalot
Senior Member
- Joined
- Nov 14, 2021
- Posts
- 241
Roof frame started on my studio floor today. 1x2 and ripped 2x. K bracing corners to help prevent racking. There will be 1/8 inch plywood on the roof portion so that’s going to help too.
Thanks! Yes- rolling along. Lift arms will arrive Monday.94 degrees with the humidity of the southern states is not for the faint of heart!
I always think that if you're running into problems, it means you're doing something good. Take a breather if you must but don't give up. It looks like you may be close to 80% done with the hardest parts, and hopefully the rest will work well and shine. It may not feel like it but I think you're beginning the home stretch to realizing your dream.
Paintsalot,At this point, I’m kind of wondering why I took on such a complicated project!! Frustrated.
, I took me 3 tries over several weeks to get what I had in my head to reality.Thanks for the encouragement. It’s always better after a break. I’m looking at how to add the roof sides now.Paintsalot,
Because it's your own design, you are bound to hit bumps in the road.
When I ripped out my underbed storage of my trailer 4 wheeling, I took me 3 tries over several weeks to get what I had in my head to reality.
Just the nature of home builds.
On the bright side, no one will have a trailer like yours and it will be as unique as you are.
Sounds are coming from springs grating inside the tube. I assumed the spring would be in the elbow, but it’s not, it’s in one of the tubes and there’s a connector that goes around the elbow, pulling it through the tube. They are very well built.Beautiful pup. She needs some TLC!
Adding to Sharon's suggestions... work some hard wax into the pivot points? It might last longer than liquids.
Still watching your build. Don't worry about how long it's taking. It's going to be a great, one of a kind trailer when you get it on the road!
Thanks- I like my vintage hand plane.Nice!
Hi Sharon,As far as whether to wrap it over the end boards or not, if you want your cedar edging to show, you could end it at the roof edge and add a small, thin prefab trim board where the canvas stops and the end boards begin. That might look nice. Trim boards can also be used to cover up seam areas in the canvas. Just another idea....
You're getting closer and closer to the finished product!![]()
