working on it
Senior Member
- Joined
- Oct 4, 2011
- Posts
- 2,205
Since I just completed the frame repair and axle/spring upgrade on my trailer,http://www.tnttt.com/viewtopic.php?f=21&t=58985 I was seeking a way to prevent a recurrence of breakage and also a way to absorb/spread the impact of large shocks to the suspension components. After much research and measurements as to which way to mount a set (requiring modifying the tie-plates for the lower mounts, and drilling more holes in the frame for the upper mounts), I wondered if all the added hardware would accomplish that task any better than a method I had used before. It seems to me that the shock and resulting jounce could be ameliorated to a satisfactory degree by inserting a progressive-rate EVS foam bump stop in between the frame and axle. Pretty much the same as Timbren uses hollow rubber "springs" in their axle-less systems, and in their Aeon line of suspension aids. I had used a similar bump stop, also mounted to be in close contact with the frame (except it was a solid polyurethane block- and was much stiffer than the EVS foam) in the rear suspension of my '86 S10 (modified for flat cornering and excessive weight loads). At first, it was very stiff and unforgiving over all surfaces, but I drilled varying sizes of holes in the poly, to create progressive stiffening, and it served me well for many years. The newer material, EVS urethane foam, acts in a progressive rate manner, without mods, so it should be what I want straight from the get-go. There was also a recent thread concerning bump stops, that served to jog my memories of my S-10 mods. So why not try what I've already done before, with success. I ordered a set of these
from Amazon. I haven't decided yet, but I will probably attach them with the mounting tabs under the axle u-bolts, so they will follow the axle movement as it travels rearward under compression. If they are too flexible for that, then I will attach the tabs thru the 1/4" thick repair piece (1/4" TEK screws?).
I will shave off about .25" (depending on actual density of the foam - TBD) from the top of the stop, and when the spring closes the gap under compression once on the ground, the bump stop will stay in constant contact with the frame, hopefully absorbing sharp impacts and reducing the major fluctuations in suspension travel. I don't expect too much spring compression anyway; the now 1600-1700 lb trailer is on a new 3500lb Dexter axle with 3000 lb/pair springs, and the 14" tires should absorb most road shock.
